Go Back   GSM-Forum > Non GSM/Mobile Related Forums > Bluetooth > Bluetooth-Software
Old 06-12-2006, 08:31   #46 (permalink)
Member: 258668
License Patcher
Originally Posted by KidJoe
Hit -> http://ambicom.com/support/installation/bt/index.htm
Download the driver for their BT2-USB dongle... they are 32bit... DriverVer=04/12/2006,5.1.0.1100
And use the LicensePatcher ZIP attached in the first post...
hi, can u pl guide as to how exactly to use the LicensePatcher application? thanx
Old 06-12-2006, 12:43   #47 (permalink)
Member: 249679
Does this driver support just USB2.0 or also 1.1/1.2 stack versions?
Thanks,
Fabio
Old 06-13-2006, 06:46   #48 (permalink)
Member: 282927
1- Uninstall all previews version
2- Reboot
3- Install widcomm 5.1.0.1100 version (dont need to unplug dongles)
4- if dongle not detect..click in cancel to continue.
5- Open control panel and change microsft bluetooth driver for CSR driver using the "Use Disk" option on driver detction (Sorry for bad english)
6- Click Starting using bluetooth and enjoy.
could someone please EXPAND on point #5 - what's this 'change driver' step?? ????
cheers
Old 06-13-2006, 13:14   #49 (permalink)
Member: 249679
It means that you have to select a different driver for the selected device in the device manager. "Use disk" is the button that specifies a different location for the inf file(s).
Cheers
Fabio
Old 06-13-2006, 14:38   #50 (permalink)
Member: 282927
thanks fabio for the reply.
er, yeah - that much is obvious - but i was hoping someone might explain
1) why another driver is required (and why it's not installed with the widcomm setup/installer).
2) Where the csr driver file is 'found'.
secondly, what about this licesene thing? when does that need to be installed. After the 5th step (above)?
cheers
Old 06-16-2006, 05:14   #51 (permalink)
Member: 282927
FYI folks, the 5.1.0.1100 installed perfectly. I didn't have to change drivers or anything also. sweet!
Old 06-18-2006, 11:22   #52 (permalink)
Member: 295929
thanks man!
i hope this **** works because ive been getting license errors for ever!
Old 06-19-2006, 00:37   #53 (permalink)
Member: 282927
You will have to run the license crack after install, of course.
Old 06-20-2006, 12:47   #54 (permalink)
Member: 296811
Please Delete this Post
Old 06-20-2006, 14:52   #55 (permalink)
Member: 167721
A2dp???
Did anyone got the A2DP working with 5.1.0.1100? My installation worked fine, run the patcher, I can discover and pair bluetooth devices. However, I cannot get the A2DP to work. I am using Nokia HS-12W, which works fine with Widcomm 4.5.xxxx. Any help will be appripriated.
Old 06-21-2006, 13:56   #56 (permalink)
Member: 296099
I was able to get my Belkin F8T012 bluetooth adapter working on XP x64 (64 bit)
How I got my Belkin F8T012 bluetooth adapter working on XP Professional x64 (64 bit) and then was able to hotsync with my TREO 700P :
I thought I needed a widcomm driver and software, but all I needed was already in x64.
All worked well for me but I guess the disclaimer is that you proceed at your own risk.
DO NOT install the Belkin software that comes with the F8T012 adapter, as this will install the widcomm drivers (not supported by x64).
Plug in the dongle into a spare USB device.
When windows asks for the driver just cancel out of this.
Then go to Start, Control Panel, System, Hardware tab, click Device Manager:
You should see something like this:
Click right mouse, select properties, Details tab, select Hardware Ids from the dropdown:
Make a note of the second value (in my case):
USB\Vid_050d&Pid_0012
Then go to:
C:\Windows\inf\bth.inf
And look for the following lines:
;------------- Device section - Start -----------------------
[ALPS.NT.5.1]
ALPS Integrated Bluetooth Device= BthUsb, USB\Vid_044e&Pid_3005
Alps Bluetooth USB Adapter= BthUsb, USB\Vid_044e&Pid_3006
[Belkin.NT.5.1]
Belkin Bluetooth Adapter= BthUsb, USB\Vid_050d&Pid_0081
Belkin Bluetooth Adapter= BthUsb, USB\Vid_050d&Pid_0084
Copy one of the lines above and add your Pid (step from above). Should look something like this:
[ALPS.NT.5.1]
[Belkin.NT.5.1]
Belkin Bluetooth Adapter= BthUsb, USB\Vid_050d&Pid_0012
Not sure what happens if you follow these steps for a device that does not have a device by the same company!
Save and close
Uninstall the unknown USB device in Device Manager.
Remove the USB dongle and then plug it back in.
You will see the “Found New Hardware Wizard” dialog again, but this time select “No, not this time” and then click next.
Then select Advance and next:
Then select “Don’t Search” and Next:
Then select “Belkin Bluetooth Adapter” (this is the link to the inf file) and click next:
This will install the driver supported for XP SP2:
Click finish:
Windows has now installed the dongle but it will also find a Microsoft Bluetooth adapter.
You will have to repeat the above again for this.
You should now get the Bluetooth Devices icon in your Control Panel.
That should be it J
Old 06-22-2006, 02:30   #57 (permalink)
Member: 295988
Thanks for the post, i'll let you know how the install goes
Old 06-26-2006, 05:40   #58 (permalink)
Member: 300298
This version is working perfectly with my Logitech MX-5000 keyboard/mouse combo however every now and then I get a message saying that this is an evaluation version of Widcomm. Any help would be appreciated.
Old 06-26-2006, 05:52   #59 (permalink)
Member: 282927
look for the PATCHER amires. it should be provided with the download if u gtabbed it from rapidshare link found in the first post of this thread.
Old 06-27-2006, 13:00   #60 (permalink)
Member: 300298
Ok thanks it did the trick.
[IMG] code is Off
Page generated in 0.53767 seconds with 11 queries
