Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #107 (permalink) | |
| Junior Member Join Date: Jan 2007
Member: 426041 Status: Offline Thanks: 0
| Quote:
Ninja1 | |
| | #111 (permalink) | |
Member: 435073 Status: Offline Thanks: 0
| Quote:
If you want to go directly to the posts and downlinks for the file you want, go to this thread. Click here. | |
| | #112 (permalink) |
| Junior Member Join Date: Aug 2005 Location: Tijuana, Baja California, Mexico Age: 30
Member: 168428 Status: Offline Thanks: 0
| @LookingAround: Many many many thanks for posting an useful - and alive - link to get the damn files. Now, I'm thinking of doing a translation of the article to Spanish. If there's an actual need for it just let me know by posting a reply here. Props to illusion for opening up the drivers |
| | #113 (permalink) |
| Junior Member Join Date: Apr 2007 Location: Detroit Michigan Area
Member: 489287 Status: Offline Thanks: 0
| A2DP with 5.1.0.1100 Not working yet. Hi! My first post here: Read the entire forum about 5 times which helped me greatly, I've been able to get 5.1.0.1100 and have it working with my dongle. Everyhing works except stereo audio to my Motorola HT820 Headset. The dongle came with a CD that includes an older Widcomm 3.xx software version and everything on that works, but is too old and does not support A2DP. A quick sanity check, running BlueSoleil demo version (5MB data limit) works just fine so I *could* purchase it to get this to work but that's no fun and I'd never learn anything ;-) Anyhow from the forum I've figured out how to install 5.1.0.110 and make it work license patch & all, but no stereo headset goodness, I am able to get 'handfree' working but that gives low quality 64kbps 8bit 'phone' quality audio. Both services show up: Motorola HT820 Hands-Free Unit --> Works -and Motorla HT820 Stereo audio --> Cannot connect : ( If I try to connect to stereo audio it just times out and fails. Did reinstalling/pairing and rebooting 6 times now no change in result. My dongle is a high power class 1 BT (100mw) *yea I can hear it a block away* no-name device (Compusa Branded on box) purchased at Compusa. I've modified the ini file and license to include it. The device uses a CSR chipset (Cambridge Silicon Radio) (not Broadcom) and doesn't work at all with the latest software downloadable at the Broadcom site. Firmware version is 1593 HCI Version : T HCI 1.1 HCI Revison : 0639 LMP Version : BT LMP 1.1 LMP Sub Version: 0639 Any ideas why the stereo audio won't connect? I noticed some people here on the forum have/had the same problem and for others it seems to just work. It does work with BlueSoleil, so I at least know the hardware can handle it. Thanks!!! Steve Last edited by SteveG; 04-15-2007 at 21:13. |
| | #114 (permalink) | |
| Junior Member Join Date: Feb 2007
Member: 454171 Status: Offline Thanks: 0
| Quote:
My recommendation is that you try the Widcomm 4.0.1.3000 drivers. I'm running that version and both A2DP and AVRCP works like a charm. The only bug I've found so far is that if you enter standby or hibernate mode while A2DP is connected you have to reboot to get A2DP working again. Dropping the A2DP connection before entering standby or hibernate mode solves the problem. | |
| | #115 (permalink) | |
| Junior Member Join Date: Oct 2006
Member: 380250 Status: Offline Thanks: 0
| Quote:
the stereo audio | |
| | #116 (permalink) |
| Junior Member Join Date: Oct 2007
Member: 621017 Status: Offline Thanks: 0
| about widcomm i read and tried but wht is "use disk" i couldn't understand. under control panel where is use disk. reply soon. if any one can help me out.plz i would appreciate u. someone would be there to help. |
| | #117 (permalink) |
| Junior Member Join Date: Dec 2003
Member: 46369 Status: Offline Thanks: 0
| Assuming you are running XP: in device manager, when you double click on your bluetooth device, you will get the device properties page. when you select the 'driver' tab and click on 'update driver' the wizard will start. Select 'no, not this time' and next, select 'install form a list or specific location' and next, select 'don't search, I will choose the driver to install and next. There you will see the 'Have Disk' option. Navigate to where your widcomm\driver\usb folder is and you should see there the inf file. Once you select the inf file you will see the device listed... |
| | #118 (permalink) |
| Junior Member Join Date: Nov 2007
Member: 625945 Status: Offline Thanks: 0
| I have a quick question and I hope it has an easy solution. I had 5.1.0.1100 patched and installed on two of the same exact laptops. I was able to use a CSR dongle perfectly fine on both laptops. The trial on one of the laptops expired so I went legit and bought a Broadcom 2045 based dongle from walmart. The software that came with the dongle is Widcomm 5.1.0.3300. I have installed the software on both laptops and the dongle works correctly on one laptop. Ive uninstalled and reinstalled repeatedly. The icon stays blue/white but I get "Your Bluetooth device could not start the search for devices" during the wizard's search for devices. Is there something that was installed in the registry/software that didnt quite get removed on the laptop that isnt working? Or are there some files that I can copy from the "working laptop" to get the "non working" laptop working properly? Right now the only version I can get working on the "non working" laptop is 5.1.0.1100 in trial mode. in short I have 2 of the same laptop runing xp sp2. Same 5.1.0.3300 installed on both. The Broadcom dongle only works on one. Any suggestions? |
| | #119 (permalink) | |
| Duuuh...I had it connected to a usb hub instead of directly to the onboard usb. Quote:
| | #120 (permalink) |
| Junior Member ![]() ![]() Join Date: Jan 2007
Member: 426437 Status: Offline Thanks: 0
| Good thread... Finally connected my Logitech Mini-BT Receiver that came with my diNovo Laser desktop... also connected my Jawbone headset... even got Logitech SetPoint installed and working. All buttons work! Crazy. The only thing remaining is the Stereo connection for my Motorola S9 - it connects fine, uses the Audio Gateway service, says it's connecting Stereo, but I can only hear mono out of one ear... No options are available to change to stereo. Grr - anyone else having A2DP issues? |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
