Unlock Server
Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Trisha & Matrix Flasher
Old 03-28-2004, 18:25   #1 (permalink)
ARC
ARC's Avatar
Member: 5019
Sonork: 100.110196
3650 - Stoped in erasing flash
Hi friends
I had a 3650 with startup problem,( it powers on, but after 5-7 sec. it resetes automatically and finally power off)
i tried to flash with matrix, everything goes well, but it stopped in 20% of erasing flash and after that i tried to flash again, but same problem appeared
now my phone does not power on at all
any solution? , please help me
thanks in advance
Old 03-28-2004, 19:22   #2 (permalink)
Yoda_Brno's Avatar
Member: 40423
What configuration of PC do u have? If running win2k try to stop applications like ICQ, disable networking, and any appz in system tray. (it may help on slower PC`s 700 - 1000 mhz) If it isn`t HW problem on your 3650 it MUST work
Old 03-28-2004, 20:30   #3 (permalink)
Windziarz's Avatar
Member: 18406
Originally Posted by ARC
Hi friends
thanks in advance
had the same problem, for me desoldering and soldering back flashes using hot air helped
Old 03-28-2004, 23:33   #4 (permalink)
Digitec's Avatar
Member: 40921
3650 is the only phone I know that is conuming too much of current from box during flashing, this could be problem with powering your box / phone. Similar is 6600. 6600 as far as I know some flash memories in 6600 dies too, too often. So be careful.
Old 03-28-2004, 23:35   #5 (permalink)
Digitec's Avatar
Member: 40921
Cool
Old 03-29-2004, 06:51   #6 (permalink)
Yoda_Brno's Avatar
Member: 40423
So i can kill fully functional phone (3650/6600) i. e. language changing with matrix???
Old 03-29-2004, 11:03   #7 (permalink)
ARC
ARC's Avatar
Member: 5019
Sonork: 100.110196
oh, my 3650 can be fixed for 20$ and now it's dead cause i tried to use my matrix
thanks for your support digitec.
Old 03-29-2004, 11:17   #8 (permalink)
ARC
ARC's Avatar
Member: 5019
Sonork: 100.110196
another thing, is that i have a 3650 locked to a network
i tried to unlock it, but it says: ERROR 02 or something like that.
what's problem?
can it be from my computer, cause i think my matrix computer is less than 700Mhz
any help?
Old 03-29-2004, 12:01   #9 (permalink)
Yoda_Brno's Avatar
Member: 40423
Try "USER AREA FORMAT" before unlock... it may help..
Old 03-29-2004, 18:34   #10 (permalink)
ARC
ARC's Avatar
Member: 5019
Sonork: 100.110196
Wink problem solved
hi friends
Problem solved
I changed my computer,
I flashed my dead 3650 successfullly and now 3650 works like before
( it powers on, backlight and then power off after 10-15 seconds)
how to solve this problem?
I already flashed MCU+PPM , but still problem not solved.
any help?
how to solve this problems (BLINK PROBLEM) on 3650 phone with matrix?
Old 03-29-2004, 21:27   #11 (permalink)
Member: 11251
if revolution 5.00 beta 4 works for you, please try to make backup of pmm memory (if something will go wrong, you will be able to restore) and set pmm file provided by this beta.
Old 03-30-2004, 09:15   #12 (permalink)
ARC
ARC's Avatar
Member: 5019
Sonork: 100.110196
I already flashed MCU+PPM, but now my phone power on and backlight will be on without nokia logo, and arround 10 seconds later, phone will be power off.
What's solution, friends?
how can i solve this problem
- USER AREA FORMAT?
I think it's for GRIFFIN users, if no please tell me how can i do it with MATRIX
Thanks
Old 04-01-2004, 05:21   #13 (permalink)
Yoda_Brno's Avatar
Member: 40423
- USER AREA FORMAT?
Thanks
Sorry, User area format was to another question (7650 unlock error -1) i writed it to bad window. But user area format is not only for Griffin users. In Koci`s revolution sw is one of the reset USER AREA FORMAT too. It solves problem on wd2 phones after flash "Phone strtup failed, please contact retailer" If u have this problem do UAF reset and phone will work normally. What FW has your 3650 before flashing??? u are trying to flash it with MCU 4.13??? (I had the same problem.MCU 3.16 to MCU 4.13 power on for 10sec blank screen and then power off. Also on griffin it does not work too. Try to flash it with MCU 3.16 (also make PMM backup before) If it will work, downgrade needs FFS and UAF after flashing, make pmm backup of your functional phone and try it flash to 4.13 again.for flashing use 5.00 BETA4 sw, for resets use old Koci`s revolutoin sw. Aser area format takes about 40sec so be patient and dont click to another reset until it writes done. FFS reset make before UAF. With mcu 3.16 it should work.
Post me result, or with problem u can contact me at icq 148777819.
Regards
Old 04-01-2004, 07:32   #14 (permalink)
Member: 25213
Originally posted by...(think it was Digitec)
"Just power on the phone, than wait till the message appear and than press "N" button twice to receive message Done. If this Done appear in left corner , just press button T (testmode) and wait till NOKIA appear on the display , than select RESETS and put 7650 format user AREA, wait 2 minutes or more and wait till Done appear."
This has worked for me on 3650 and 7650
(Oops, sorry, this is for "phone startup failed, contact the retailer)
Old 04-01-2004, 08:27   #15 (permalink)
Jumanji's Avatar
Member: 58189
The answer bad contacts on your connector. I did have this problem
br
Stoping iphone erase proccess owoblow iPhone ,iPod & iPad (Apple Inc. Products) 3 09-21-2009 01:14
Help Me In Erase Files For Nokia 3650 zonetrichur Nokia Hardware & Hardware-Repair Area 2 11-26-2007 08:52
Flash with Mt-Box stoped in erasing said4 MT-BOX 7 02-19-2007 21:34
Big Problem erasing flash a 3650 before flashing !! humbedj UFS2 + UFS3-Tornadoflasher 12 08-15-2006 11:27
Whenever erase flash viewdb-stoped at 15,6% Lugo Alcatel & TCL Old Models 3 06-28-2000 17:28
Page generated in 0.43249 seconds with 11 queries
