Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Trisha & Matrix Flasher
Old 12-04-2003, 00:29   #1 (permalink)
MobileSoft's Avatar
Member: 3355
Red face 5100 Flash Problems
HI all - pls help!
I have tried to flash my 5100. It goes through whole procedure and after loading content package - just as the phone goes into loacal mode - it gets stuck there and does not go further.
Now phone dont work anymore.
Also when you force on - no work, or when you try to read info - no work. Please help - Now I am foneless!
Old 12-04-2003, 02:13   #2 (permalink)
aba1999's Avatar
Member: 15615
1. Try to flash few time again first , allmost allways help .
2. Check your PC settings and external Matrix power suplly (700mA)
3. Read all message on this section , 100 % would help .
WBR ,
Benjamin
Old 12-04-2003, 04:44   #3 (permalink)
MobileSoft's Avatar
Member: 3355
Hi,
1)Flashed 15 x so far - No Luck
2)Tried on 3 different pc's
3)Read this whole forum - Cant find anyting!
Old 12-04-2003, 07:01   #4 (permalink)
Member: 43572
Hi
I now that matrix give some problem with dct3 phone and digitec issued a mod to matrix I have done it and it works for me but also I have never try to flash mobile before that time try it may that you have ?
Regards
MaRvIk
Old 12-04-2003, 07:17   #5 (permalink)
MobileSoft's Avatar
Member: 3355
if this is the mod where you connect wire from one hole to the one lifted leg of ic - i have done it - still no work
Old 12-04-2003, 11:39   #6 (permalink)
Member: 43572
Hi again then try this just click on skip blue tooth when i tried the first time to flash my 7650 it was giving me an error 95 then hang up when flash and i have to close the program and all this sort off thinks try that if you want in the forum there are a topic about me for gething help to flash the 7650 try to look there ok may know you get some were ??
Regards
MaRvIk
Old 12-04-2003, 12:13   #7 (permalink)
MobileSoft's Avatar
Member: 3355
Sorry man - still not work!
Old 12-05-2003, 23:47   #8 (permalink)
Digitec's Avatar
Member: 40921
Was your phone good before? I just tried to FLASH my 5100 and no problem at all regardless on loaders or other things - so the q. is was the phone in good conditions before you have flashed it - NEW ONE? or some used one? There was never reported any problem with this phone before. If I understood well, phone stopped communicating after data pack uploading - Let me know where you get your flash files too. The problem could be flashing cable itself.
Be sure you have disconnected PIN 28 of Matrix PROCESSOR from the socket.
Old 12-06-2003, 05:49   #9 (permalink)
MobileSoft's Avatar
Member: 3355
tnx digitec... phone was new - will try removing pin 28 from processor and report results back here!
Old 12-06-2003, 07:36   #10 (permalink)
MobileSoft's Avatar
Member: 3355
@digitec - Removed pin 28 - matrix box work fine now - THANKS EVERYONE FOR HELP!
E52 RM-469 Flashing problem.Flash ID not supported for this loader (RAPUv11_algo_xsr1 rafik2533 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 04-04-2010 20:38
nokia 5100 flashing problem HELPPPPPP MEEE maniek27 Nokia Hardware & Hardware-Repair Area 1 06-18-2005 15:04
nokia 5100 display problem nilan Nokia Hardware & Hardware-Repair Area 4 04-18-2005 14:40
problem with 5100 flashing doberman Griffin 0 03-24-2004 15:51
Nokia 5100 flash problem kon-tiki Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 10-17-2003 16:31
Page generated in 0.44197 seconds with 11 queries
