01-10-2004, 02:31 | #7 (permalink) |
Freak Poster Join Date: Oct 2003 Age: 55
Member: 40921 Status: Offline Thanks Meter: 0 | Hi to all. 6600 case solving whole afternoon. 6600 cables delivered with Matrix need to be modified. There is middle contact in service battery on the connector. You need open the 6600 connector and solder out the wire from the middle point (between plus (+) and minus (-)) THIS BSI wire need to be connected the RESISTOR 2K2, and the second part of resistor leads to BSI on the connector. After this moddification, you can power on the phone on the service battery and put the PHONE to TEST MODE, READ INFO , etc w/o switching off the phone after manual power on. In FACT there is NOKIA TRICK to FORMAT user area in Symbians Phones. Press GREEN BUTTON, *, and 3 on the 6600 phone than power on button while keeping pressed all the 3 buttons, the phone start up formating user AREA itself w/o any wires - it means - this ought to help. Please comment. |
01-10-2004, 05:55 | #8 (permalink) |
Freak Poster Join Date: Nov 2003 Location: moon Age: 53
Member: 43572 Status: Offline Thanks Meter: 0 | Hi roman here are many people from all Europe and some are not technical as other if you can you take a photo and show them the work that have to be than? for me problem solved because a week ago i received the wire and works Regards MaRvIk |
01-12-2004, 00:56 | #10 (permalink) |
Freak Poster Join Date: Jul 2003 Location: Enschede, Netherlands Age: 41
Member: 34652 Status: Offline Thanks Meter: 5 | Can this mod also be used in the 3650 cable, because this also has difficulties entering Local-, Test- and Normal mode? Maybe something for the Matrix Team to think about.... |
01-12-2004, 14:25 | #11 (permalink) |
No Life Poster Join Date: Apr 2002
Member: 10964 Status: Offline Thanks Meter: 285 | @digitec how long (minutes) does it take to format using the keypad sequence? it shows formatting and a progress bar as large as the whole screen and after 10 sec it's getting blocked (no pregress on progress bar ) thanks sorinm |
01-13-2004, 15:30 | #14 (permalink) |
No Life Poster Join Date: May 2002 Location: Portugal.dll
Member: 11915 Status: Offline Thanks Meter: 10 | Matrix buddy's, All WD4 phones , after ''phone start up failure'' , need press twice in ''N'' (normal mode) , after that just press ''T'' (test mode) and you will see [GLOW=royalblue]NOKIA[/GLOW] , after that u can make all reset's . . . Good luck, DaysGSM PS- Pay attention , if u flashed phone make sure u maked ''after flash'' with same pack u flashed phone , if not , u may never remove ''start up failure'' |
01-13-2004, 15:40 | #15 (permalink) |
Member: 11915 Status: Offline Thanks Meter: 10 | @Mastah-GSi In 3650 , after connect to Matrix , just press 1 or 2 times in normal mode , after, you will see all ''modes'' working 100000% Good luck, DaysGSM Last edited by DaysGSM; 01-13-2004 at 16:29. |
Nokia 6600 phone startup failed can’t format User aria | Miftahudin | MT-BOX | 14 | 04-04-2010 14:25 |
** n91(rm43) Phone startup failure Contact the retailre** | prasu | Nokia Hardware & Hardware Repair | 1 | 10-17-2008 15:10 |
Nokia 6600 Phone Startup Failed Contact Retailer | ktelecom | WD2 & APE (Symbian Phones) | 16 | 05-01-2007 11:55 |
N70 after wirte RPL is Phone Startup Failure | begginer | MT-BOX | 4 | 01-29-2007 13:13 |
