Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Trisha & Matrix Flasher
Old 12-02-2003, 13:43   #1 (permalink)
MobileSoft's Avatar
Member: 3355
Unhappy HELP: Dejan Interface not working properly
If I use the dct3 switch on my box to activiate the dejan interface and i use 3rd part software for eg: kNok or Rolis etc, It starts the flash erasing procedure and when writing it gives me an error: "Flash Erasing Error: Must recieve 91 00 FF, but recieved 11 00 FF. Check VPP, VBat Voltage, Phone Type..."
I have tried different voltages from 7.5v right to 12v. I also tried amperage on powersupply from 750mA to 1000mA. Always get this error. This happens on all DCT3 phones.
Please help asap!
Thanks
Old 12-02-2003, 15:32   #2 (permalink)
fgl30's Avatar
Member: 27881
Thanks Meter: 11
It seems phone fault, not box fault. Did you try with another phones? Since sw start flash procedure, mean that communication protocol of the box-pc-phone is working (I guess.....)
Old 12-02-2003, 17:34   #3 (permalink)
MobileSoft's Avatar
Member: 3355
erm... i did say above that this happens on ALL DCT3 phones... meaning that i HAVE tried many others. NOT one worked. Tried 3310; 3330; 5110; 5210 and 6210. All do the same above... NONE work!
But thanks anyway for your help... Any Matrix member can help please!????
Old 12-03-2003, 17:27   #4 (permalink)
MobileSoft's Avatar
Member: 3355
WOULD SOMEBODY FROM MATRIX TEAM PLASE HELP - THIS IS URGENT!
Old 12-03-2003, 18:47   #5 (permalink)
MiH
MiH's Avatar
Member: 18876
Thanks Meter: 27
What is your PCB revision?
Old 12-03-2003, 22:16   #6 (permalink)
MobileSoft's Avatar
Member: 3355
i cant check because the box has a warrant seal on it ,
but it should be the latest because its only 2weeks old and already came with upgraded revolution PIC in it!
Old 12-04-2003, 01:26   #7 (permalink)
MobileSoft's Avatar
Member: 3355
Ok - my pcb revision is: 22-08-03, I have done the mod from the pwr leg of the ic to the through hole on the pcb - the same mod digitec explained in one of his post - STILL NO WORK!!!!!
Old 12-04-2003, 12:45   #8 (permalink)
John_Doe's Avatar
Member: 1879
Sonork: 100.28016
Thanks Meter: 941
dejan 1.00b interface donīt like all PC mainboards. Please try on another PC before sending the box back for exchange.
Old 12-04-2003, 12:53   #9 (permalink)
Member: 43572
did you try other software ? try the rolis 4.77 may you can flash your mobile with this software it works ok for me
Regards
MaRvIk
Old 12-04-2003, 13:17   #10 (permalink)
MobileSoft's Avatar
Member: 3355
@marvic
did rolis 4,77 - no work!
@ JD
Same story on other pc.
On digitec's mod he mentions something about changing resistors, but does not give resistor values - do u have these value so i can try this before sending box for exchange as last resort?
Old 12-04-2003, 15:11   #11 (permalink)
Member: 43572
i think thay are saying 560omh but ??? but all that i did is to take r2 and swap it with r8 i thing that digitec want to mean it like this sorry but i just had electrical fearer
Regards
MaRvIk
Old 12-05-2003, 22:43   #12 (permalink)
MobileSoft's Avatar
Member: 3355
tnx marvik - will try this out tomorrow and post results here
Old 12-06-2003, 01:37   #13 (permalink)
Digitec's Avatar
Member: 40921
there is req. modification as I mentioned on 29.11. - less voltage on POWER PIN of 74HC14 ! This is the cause - near sure.
Old 12-06-2003, 08:58   #14 (permalink)
MobileSoft's Avatar
Member: 3355
@digitec - Thanks once again - swaped r2 with r8 - phone flashed now with no problems
However I have noticed another problem... When you want to read dct3 phone data, and if i use NokiaTool 035 - Phone infois read - BUT if i use Nokia Tool by Koci 3.12 - Then phone info not read - Same problem with rolis. Any ideas on how to sort this out - cos i really dig Koci Nokia Tool?
Old 12-06-2003, 10:27   #15 (permalink)
Digitec's Avatar
Member: 40921
Nokia Tool by Koci works on M-BUS, not on Dejan interface, so be so good and switch to DCT4 possition (SWITCH UP) for M-BUS/F-US interface to be able to read by Any M-BUS/F-BUS tool.
c62 client does not works properly on 70% of phones uu1dx Griffin 13 04-25-2005 15:46
3g unlocker cracked not working properly nokia_dan NEC 0 01-06-2005 18:11
Nokia 6600 LCD not working properly, no camera function ! NaaN WD2 & APE (Symbian Phones) 3 01-18-2004 12:35
8250 not working properly pks Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 01-22-2003 02:38
BDM not working properly. Please help. trox Motorola Old Legacy (EMMI) 1 04-05-2000 22:45
Page generated in 0.21608 seconds with 10 queries
