12-02-2003, 13:43 | #1 (permalink) |
Freak Poster Join Date: Feb 2001 Location: South Africa
Member: 3355 Status: Offline Thanks Meter: 1 | HELP: Dejan Interface not working properly I have tried different voltages from 7.5v right to 12v. I also tried amperage on powersupply from 750mA to 1000mA. Always get this error. This happens on all DCT3 phones. Please help asap! Thanks |
12-02-2003, 15:32 | #2 (permalink) |
No Life Poster Join Date: May 2003
Member: 27881 Status: Offline Thanks Meter: 11 | It seems phone fault, not box fault. Did you try with another phones? Since sw start flash procedure, mean that communication protocol of the box-pc-phone is working (I guess.....) |
12-02-2003, 17:34 | #3 (permalink) |
Member: 3355 Status: Offline Thanks Meter: 1 | erm... i did say above that this happens on ALL DCT3 phones... meaning that i HAVE tried many others. NOT one worked. Tried 3310; 3330; 5110; 5210 and 6210. All do the same above... NONE work! But thanks anyway for your help... Any Matrix member can help please!???? |
12-03-2003, 22:16 | #6 (permalink) |
Member: 3355 Status: Offline Thanks Meter: 1 | i cant check because the box has a warrant seal on it , but it should be the latest because its only 2weeks old and already came with upgraded revolution PIC in it! |
12-04-2003, 01:26 | #7 (permalink) |
Member: 3355 Status: Offline Thanks Meter: 1 | Ok - my pcb revision is: 22-08-03, I have done the mod from the pwr leg of the ic to the through hole on the pcb - the same mod digitec explained in one of his post - STILL NO WORK!!!!! |
12-04-2003, 12:45 | #8 (permalink) | |
No Life Poster Join Date: Aug 2000 Location: anywhere
Member: 1879 Status: Offline Sonork: 100.28016 Thanks Meter: 941 | Quote:
12-04-2003, 13:17 | #10 (permalink) |
Member: 3355 Status: Offline Thanks Meter: 1 | @marvic did rolis 4,77 - no work! @ JD Same story on other pc. On digitec's mod he mentions something about changing resistors, but does not give resistor values - do u have these value so i can try this before sending box for exchange as last resort? |
12-04-2003, 15:11 | #11 (permalink) |
Freak Poster Join Date: Nov 2003 Location: moon Age: 53
Member: 43572 Status: Offline Thanks Meter: 0 | i think thay are saying 560omh but ??? but all that i did is to take r2 and swap it with r8 i thing that digitec want to mean it like this sorry but i just had electrical fearer Regards MaRvIk Last edited by marvik; 12-04-2003 at 20:31. |
12-06-2003, 08:58 | #14 (permalink) |
Member: 3355 Status: Offline Thanks Meter: 1 | @digitec - Thanks once again - swaped r2 with r8 - phone flashed now with no problems However I have noticed another problem... When you want to read dct3 phone data, and if i use NokiaTool 035 - Phone infois read - BUT if i use Nokia Tool by Koci 3.12 - Then phone info not read - Same problem with rolis. Any ideas on how to sort this out - cos i really dig Koci Nokia Tool? |
12-06-2003, 10:27 | #15 (permalink) |
Freak Poster Join Date: Oct 2003 Age: 55
Member: 40921 Status: Offline Thanks Meter: 0 | Nokia Tool by Koci works on M-BUS, not on Dejan interface, so be so good and switch to DCT4 possition (SWITCH UP) for M-BUS/F-US interface to be able to read by Any M-BUS/F-BUS tool. |
c62 client does not works properly on 70% of phones | uu1dx | Griffin | 13 | 04-25-2005 15:46 |
3g unlocker cracked not working properly | nokia_dan | NEC | 0 | 01-06-2005 18:11 |
Nokia 6600 LCD not working properly, no camera function ! | NaaN | WD2 & APE (Symbian Phones) | 3 | 01-18-2004 12:35 |
8250 not working properly | pks | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 01-22-2003 02:38 |
BDM not working properly. Please help. | trox | Motorola Old Legacy (EMMI) | 1 | 04-05-2000 22:45 |
