HELP: Dejan Interface not working properly If I use the dct3 switch on my box to activiate the dejan interface and i use 3rd part software for eg: kNok or Rolis etc, It starts the flash erasing procedure and when writing it gives me an error: "Flash Erasing Error: Must recieve 91 00 FF, but recieved 11 00 FF. Check VPP, VBat Voltage, Phone Type..." I have tried different voltages from 7.5v right to 12v. I also tried amperage on powersupply from 750mA to 1000mA. Always get this error. This happens on all DCT3 phones. Please help asap! Thanks |
It seems phone fault, not box fault. Did you try with another phones? Since sw start flash procedure, mean that communication protocol of the box-pc-phone is working (I guess.....) |
erm... i did say above that this happens on ALL DCT3 phones... meaning that i HAVE tried many others. NOT one worked. Tried 3310; 3330; 5110; 5210 and 6210. All do the same above... NONE work! But thanks anyway for your help... Any Matrix member can help please!???? |
WOULD SOMEBODY FROM MATRIX TEAM PLASE HELP - THIS IS URGENT! |
What is your PCB revision? |
i cant check because the box has a warrant seal on it :(, but it should be the latest because its only 2weeks old and already came with upgraded revolution PIC in it! |
Ok - my pcb revision is: 22-08-03, I have done the mod from the pwr leg of the ic to the through hole on the pcb - the same mod digitec explained in one of his post - STILL NO WORK!!!!! :( |
did you try other software ? try the rolis 4.77 may you can flash your mobile with this software it works ok for me Regards MaRvIk |
@marvic did rolis 4,77 - no work! @ JD Same story on other pc. On digitec's mod he mentions something about changing resistors, but does not give resistor values - do u have these value so i can try this before sending box for exchange as last resort? |
i think thay are saying 560omh but ??? but all that i did is to take r2 and swap it with r8 i thing that digitec want to mean it like this sorry but i just had electrical fearer Regards MaRvIk |
tnx marvik - will try this out tomorrow and post results here :) |
there is req. modification as I mentioned on 29.11. - less voltage on POWER PIN of 74HC14 ! This is the cause - near sure. |
@digitec - Thanks once again - swaped r2 with r8 - phone flashed now with no problems :) However I have noticed another problem... When you want to read dct3 phone data, and if i use NokiaTool 035 - Phone infois read - BUT if i use Nokia Tool by Koci 3.12 - Then phone info not read - Same problem with rolis. Any ideas on how to sort this out - cos i really dig Koci Nokia Tool? |
Nokia Tool by Koci works on M-BUS, not on Dejan interface, so be so good and switch to DCT4 possition (SWITCH UP) for M-BUS/F-US interface to be able to read by Any M-BUS/F-BUS tool. |
