Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2001 Location: South Africa
Member: 3355 Status: Offline Thanks: 0
| If I use the dct3 switch on my box to activiate the dejan interface and i use 3rd part software for eg: kNok or Rolis etc, It starts the flash erasing procedure and when writing it gives me an error: "Flash Erasing Error: Must recieve 91 00 FF, but recieved 11 00 FF. Check VPP, VBat Voltage, Phone Type..." I have tried different voltages from 7.5v right to 12v. I also tried amperage on powersupply from 750mA to 1000mA. Always get this error. This happens on all DCT3 phones. Please help asap! Thanks |
| | #2 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2003
Member: 27881 Status: Offline Thanks: 0
| It seems phone fault, not box fault. Did you try with another phones? Since sw start flash procedure, mean that communication protocol of the box-pc-phone is working (I guess.....) |
| | #3 (permalink) |
| erm... i did say above that this happens on ALL DCT3 phones... meaning that i HAVE tried many others. NOT one worked. Tried 3310; 3330; 5110; 5210 and 6210. All do the same above... NONE work! But thanks anyway for your help... Any Matrix member can help please!???? |
| | #6 (permalink) |
| i cant check because the box has a warrant seal on it ,but it should be the latest because its only 2weeks old and already came with upgraded revolution PIC in it! |
| | #7 (permalink) |
| Ok - my pcb revision is: 22-08-03, I have done the mod from the pwr leg of the ic to the through hole on the pcb - the same mod digitec explained in one of his post - STILL NO WORK!!!!! |
| | #8 (permalink) | |
| Freak Poster ![]() ![]() ![]() Join Date: Aug 2000 Location: anywhere
Member: 1879 Status: Offline Sonork: 100.28016 Thanks: 164
| Quote:
| | #10 (permalink) |
| @marvic did rolis 4,77 - no work! @ JD Same story on other pc. On digitec's mod he mentions something about changing resistors, but does not give resistor values - do u have these value so i can try this before sending box for exchange as last resort? |
| | #11 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2003 Location: moon Age: 42
Member: 43572 Status: Offline Thanks: 0
| i think thay are saying 560omh but ??? but all that i did is to take r2 and swap it with r8 i thing that digitec want to mean it like this sorry but i just had electrical fearer Regards MaRvIk Last edited by marvik; 12-04-2003 at 19:31. |
| | #14 (permalink) |
| @digitec - Thanks once again - swaped r2 with r8 - phone flashed now with no problems ![]() However I have noticed another problem... When you want to read dct3 phone data, and if i use NokiaTool 035 - Phone infois read - BUT if i use Nokia Tool by Koci 3.12 - Then phone info not read - Same problem with rolis. Any ideas on how to sort this out - cos i really dig Koci Nokia Tool? |
| | #15 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Oct 2003 Age: 44
Member: 40921 Status: Offline Thanks: 0
| Nokia Tool by Koci works on M-BUS, not on Dejan interface, so be so good and switch to DCT4 possition (SWITCH UP) for M-BUS/F-US interface to be able to read by Any M-BUS/F-BUS tool. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| c62 client does not works properly on 70% of phones | uu1dx | Griffin | 13 | 04-25-2005 15:46 |
| 3g unlocker cracked not working properly | nokia_dan | NEC | 0 | 01-06-2005 17:11 |
| Nokia 6600 LCD not working properly, no camera function ! | NaaN | WD2 & APE (Symbian Phones) | 3 | 01-18-2004 11:35 |
| 8250 not working properly | pks | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 1 | 01-22-2003 01:38 |
| BDM not working properly. Please help. | trox | Old Legacy Motorola (EMMI) | 1 | 04-05-2000 22:45 |
