11-15-2003, 11:50 | #1 (permalink) |
No Life Poster Join Date: Aug 2000 Location: anywhere
Member: 1879 Status: Offline Sonork: 100.28016 Thanks Meter: 941 | if your have problems with flashing.... we found out that there are a few boxes out there that are not working properly because of a small mistake on the PCB. if you´re getting error message 0203 or timeout and you cannot flash then you have probably one of those boxes. in order to fix this, just open the housing of the box and disconnect(or cut) PIN28 from the Processor. regards, |
11-15-2003, 12:18 | #2 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Portugal- Center of Europe Age: 42
Member: 9502 Status: Offline Thanks Meter: 9 | i done that but not work until now. check my post http://forum.gsmhosting.com/vbb/show...hreadid=112290 |
12-18-2003, 00:15 | #4 (permalink) |
Freak Poster Join Date: Jul 2003 Location: Enschede, Netherlands Age: 41
Member: 34652 Status: Offline Thanks Meter: 5 | I also got a box that gives error 0203. It occurs with a 8310. I think that the problem here is a malfunction in the 8310 cable. The problem occurs when trying to flash the phone. Read info from phone and unlocking from phone works 100%. Customer is coming over tomorrow for a test with his box, cable and some 8310's phones and we'll test it together. But I think it's a cable malfunction, because the pin28 is already removed and stuff. Last edited by Mastah-GSi; 12-18-2003 at 11:27. |
If you have problems with keyboard letters after install ust, here is easy solution!! | misiu22 | UST Pro II | 7 | 11-03-2009 14:54 |
If you have problem with unlocking Benq-Siemens please read this topic!!! | blang | Z3X-Team Products | 32 | 10-29-2009 12:24 |
if you have problem with nokia hard see this post | flash-mobi | Nokia Hardware & Hardware Repair | 24 | 11-08-2008 06:40 |
Please Post Here If you have problem with corrupted file after 16-06-2007 | MicrostarGSM® | MT-BOX | 2 | 06-20-2007 13:13 |
Read this if you have problems with cookies and login! | johny3310 | Board, Server and Login Problems/Support | 0 | 04-23-2003 14:56 |
