11-18-2003, 22:19 | #1 (permalink) |
Freak Poster Join Date: Jul 2003 Location: Enschede, Netherlands Age: 41
Member: 34652 Status: Offline Thanks Meter: 5 | Matrix won't flash phones.... the Matrix Revolution won't flash these phones: 8210, 3310, 6310i, 3510,3510i, 6210 and a 9210 (with broken inside display) But it did flash a 7210. Unlocking works 100% for DCT3 and DCT4. What can be the problem?? Please help!! |
11-18-2003, 22:46 | #2 (permalink) |
Freak Poster Join Date: Sep 2002 Location: Travnik , BiH Age: 55
Member: 15615 Status: Offline Thanks Meter: 0 | Please , before put new topics , read carefully all message here or use search engine . People have only problems with Matrix cable and connectors . Somebody find glue on connectors , somebody must remove plastic around connectors pin , bla , bla , bla . Somebody not setup PC , somebody not remove attributes from files , bla , bla , bla . Chek older posts and try to find what is problem in your case. WBR , Benjamin |
11-19-2003, 11:32 | #3 (permalink) |
No Life Poster Join Date: May 2003
Member: 27881 Status: Offline Thanks Meter: 11 | aba1999 is quite right........ FIRST RULE in flashing work: check your cables, SECOND RULE, check your cables again, and last: revise your cables connection......... 90% of all time out problems are cable faults............... |
11-29-2003, 06:13 | #5 (permalink) |
Freak Poster Join Date: Oct 2003 Age: 55
Member: 40921 Status: Offline Thanks Meter: 0 | cables and PCB Well Matrix is in fact much more complex than it seems - it is more that one processor plugged into Pararel PORT and that is why there are more problems than our competitions have got with their products. The resistors and capacitors are sometimes soldered not well enought - if u are user of this low QC Matrix box and if u can, try resolder all parts on board, do it. If not, simply return the box to the dealer and wait for new one - there is warranty of hardware you bougt from us. I'm a little bit sorry to hear that the quality of all cables is low - I would not say so, but in fact could be always better as anything. I'm user of all product on the market and all 3-rd party cables are near same. If someone needs really quality cables, ask Nokia please, their cables are pretty tough and pretty expensive. |
Rsdlite3,3 won't reconize phone | topfrog65 | GOT Motorola | 0 | 06-03-2007 17:17 |
Sonyericsson won't cover warranty on unlocked/flashed phones | m_dige | Cruiser Suite | 22 | 03-23-2006 14:38 |
8210 won't turn on and won't flashing at all | hooi76 | Nokia Hardware & Hardware Repair | 4 | 06-28-2004 14:00 |
matrix succefull flash nokia 6600 | toufik | Trisha & Matrix Flasher | 1 | 04-13-2004 06:33 |
Matrix flasher flash filez support home page TEST | Digitec | Trisha & Matrix Flasher | 38 | 12-16-2003 22:31 |
