Nokia 1100 direct unlock with Matrix possible ? Matrix flasher can flash Nokia 1100 and make direct unlock ? |
Hey ! Any reply ? |
use Nokia Code Calculator, I tried it successfull... |
I have code counter empty. I can't enter code :( With that provider you tyed codes unlock solution ? |
1100 is possible to unlock directly with our Matrix. It will give error -7 after unlocking, but it is unlocked. -7 is phone message OK on algo 7. You will need resistor on BSI 2K2 in serial to BSI signal. |
really ???????? how about cable diagram ? ha.....ha..Digitec ( Roman ) Merry Chrishmas and Happy New Year 2004 , I hope and pray , after this , you to be kindly and gentleman too for ever.............:) ;) :rolleyes: |
It is working with N-GAGE cable for me fine. Just 2k2 necessary to add in serial connection to BSI signal. |
digitec can you explain better thaz 2k2? what do to? |
@sergioems , 2k2 is resistor 2,2 kilo omh @digitec , you use cable ngage to 1100 ? you bend the pin ? you answer only without have knowladge, ha....ha.. |
Yes I use N-GAGE cable for 1100 now, I'm waiting for 1100 original cables, N-GAGE is possible to use. Pinout is same. 1100 has bigger distance but with small flexing the GND pin, you can use N-GAGE on 1100 as I do. |
I will try unlock phone and i will post result here. |
NOT WORK !!!!!!!!!!!!!!!!! I SEE ERROR -7 ,but phone locked :( Phone detected Type: 2 :mad: |
