Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Trisha & Matrix Flasher
Old 12-11-2003, 10:40   #1 (permalink)
Anno's Avatar
Member: 8360
Arrow Nokia 1100 direct unlock with Matrix possible ?
Matrix flasher can flash Nokia 1100 and make direct unlock ?
Old 12-11-2003, 23:17   #2 (permalink)
Anno's Avatar
Member: 8360
Hey ! Any reply ?
Old 12-13-2003, 05:21   #3 (permalink)
Member: 37430
use Nokia Code Calculator, I tried it successfull...
Old 12-13-2003, 09:35   #4 (permalink)
Anno's Avatar
Member: 8360
I have code counter empty.
I can't enter code
With that provider you tyed codes unlock solution ?
Old 12-26-2003, 02:14   #5 (permalink)
Digitec's Avatar
Member: 40921
1100 is possible to unlock directly with our Matrix. It will give error -7 after unlocking, but it is unlocked. -7 is phone message OK on algo 7. You will need resistor on BSI 2K2 in serial to BSI signal.
Old 12-26-2003, 02:25   #6 (permalink)
Member: 8761
really ???????? how about cable diagram ?
ha.....ha..Digitec ( Roman ) Merry Chrishmas and Happy New Year 2004 , I hope and pray , after this , you to be kindly and gentleman too for ever.............
Old 12-26-2003, 04:25   #7 (permalink)
Digitec's Avatar
Member: 40921
It is working with N-GAGE cable for me fine. Just 2k2 necessary to add in serial connection to BSI signal.
Old 12-26-2003, 14:39   #8 (permalink)
sergioems's Avatar
Member: 9502
digitec can you explain better thaz 2k2? what do to?
Old 12-26-2003, 15:02   #9 (permalink)
Member: 8761
@sergioems , 2k2 is resistor 2,2 kilo omh
@digitec , you use cable ngage to 1100 ? you bend the pin ? you answer only without have knowladge, ha....ha..
Old 12-28-2003, 13:42   #10 (permalink)
Digitec's Avatar
Member: 40921
Yes I use N-GAGE cable for 1100 now, I'm waiting for 1100 original cables, N-GAGE is possible to use. Pinout is same. 1100 has bigger distance but with small flexing the GND pin, you can use N-GAGE on 1100 as I do.
Old 12-28-2003, 20:17   #11 (permalink)
Anno's Avatar
Member: 8360
I will try unlock phone and i will post result here.
Old 12-29-2003, 09:24   #12 (permalink)
Anno's Avatar
Member: 8360
NOT WORK !!!!!!!!!!!!!!!!! I SEE ERROR -7 ,but phone locked
Phone detected Type: 2
Nokia 6500s Direction Keypad with Diamond (silver) - Original IPMART ipmart WebShop 0 09-25-2008 14:20
KG220:I made direct unlock with Easy-Unlocker & now just shows logo & power-off..?? beneto LG 2 06-20-2008 18:15
Nokia 3650 Direct Unlocker mdshad1 Nokia Multimedia 3 11-01-2003 01:57
new ! nokia dct direct unlocker, moto clip unlockmobile Main Sales Section 19 07-04-2002 23:00
Page generated in 0.90240 seconds with 11 queries
