08-09-2012, 19:19 | #1 (permalink) |
Insane Poster Join Date: Apr 2011
Member: 1558098 Status: Offline Thanks Meter: 3 | 1209 flash device not supported write flash results 1st Boot: Ok, DCT4, UPP: 2292 [Rh-105] [2.2.0.0] 2nd Boot: u3_2nd.fia, Ver: 4.79.0 Fl0: 0x01000000-0x01FFFFFF,00208820,St No Name FLASH DEVICE NOT SUPPORTED Check Product, Use newer Flash Loader Pack Algorithm: u3_st_i.fia, Ver: 4.79.0 2nd Boot Error: Error Data1: 00000000: 9F 03 02 01 00 20 88 20 00 00 02 21 00 00 02 00 ..... . ...!.... 00000010: 00 00 01 00 00 00 00 00 00 AD 7E B6 12 1B BE 0A ..........~..... 00000020: E2 AD 7E B6 12 1B BE 0A E2 9B 00 00 00 00 00 00 ..~............. 00000030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Error Data2: 00000000: 11 11 11 11 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00000010: 00 00 00 00 00 00 AD 7E B6 12 1B BE 0A E2 AD 7E .......~.......~ 00000020: B6 12 1B BE 0A E2 9B D3 72 00 00 00 00 00 00 00 ........r....... 00000030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Before taking screenshot, expand this window ! Process Failed, Repowering Mobile |
The Following User Says Thank You to kadiadi For This Useful Post: |
08-09-2012, 20:12 | #5 (permalink) | |
Freak Poster Join Date: Jul 2011 Location: Unknown World
Member: 1611261 Status: Offline Sonork: 1677675 Thanks Meter: 62 | 1209 flash device not supported Quote:
It's The Problem From Flash IC After rehot Remain Same then Change Flash Ic | |
08-09-2012, 20:19 | #6 (permalink) |
Member: 1558098 Status: Offline Thanks Meter: 3 | Thank you brother so mutch for your answer. Yeah its a hardwar problem but where is flasher ic and wahat is pcb. I do not knew the name of flash ic. All zhat i have done till now :cleaning motherboard with gasoline and precision lectronic cleaning solvent then rehoting UEM by hot air without flux :157c degree but no thing has changed. |
08-09-2012, 20:29 | #7 (permalink) | |
Moderator Join Date: Dec 2010 Location: Malaysia
Member: 1464783 Status: Offline Thanks Meter: 1,091 | Quote:
flash ic is beside uem ic rehot with 300c,but be careful BR Nizda Mobile | |
08-10-2012, 02:04 | #14 (permalink) |
Member: 1558098 Status: Offline Thanks Meter: 3 | I read in other forums that such problem can be solved by cleaning the upp and the uem. 1st Boot: Ok, DCT4, UPP: 2292 [Rh-105] [2.2.0.0] 2nd Boot: u3_2nd.fia, Ver: 4.79.0 Fl0: 0x01000000-0x01FFFFFF,00000001, UNKNOWN CHIP ! FLASH DEVICE NOT SUPPORTED Check Product, Use newer Flash Loader Pack Algorithm: u_intel.fia, Ver: 4.80.0 2nd Boot Error: Error Data1: 00000000: 9F 03 02 01 00 00 00 01 00 00 00 00 00 00 02 00 ................ 00000010: 00 00 01 00 00 00 00 00 00 00 00 00 01 00 02 00 ................ 00000020: 03 01 0C 01 0D 01 0E 01 0F B5 00 00 00 00 00 00 ................ 00000030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Error Data2: 00000000: 11 11 11 11 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00000010: 00 00 00 00 00 00 00 00 00 01 00 02 00 03 01 0C ................ 00000020: 01 0D 01 0E 01 0F B5 D3 72 00 00 00 00 00 00 00 ........r....... 00000030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Before taking screenshot, expand this window ! |
08-10-2012, 10:53 | #15 (permalink) |
Member: 1611261 Status: Offline Sonork: 1677675 Thanks Meter: 62 | 1209 flash device not supported MCU = Master Control Unit PPM = Post Programmable Memory UPP = UNIVERSAL PHONE PROCESSOR UPP indicate that the flash prommer is connected |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
