03-30-2006, 12:59 | #1 (permalink) |
Registered User Join Date: Jan 2005 Age: 46
Member: 111373 Status: Offline Thanks Meter: 25 | 1st Boot Err: Bad Resp UFSx Please help RajSE 1st Boot Err: Bad Resp UFSx Process Failed, Repowering Mobile |
03-30-2006, 14:00 | #3 (permalink) |
No Life Poster Join Date: Aug 2003 Location: BiH
Member: 37090 Status: Offline Thanks Meter: 42 | In general, it's USB drivers related problem. If you want to work with UFS without similar problems, try to keep your PC system as much clean as possible. I have one partition reserved for unlocking software (original, like Saras, Griffin, SST...) - pure Win OS with basic drivers needed for work, even without antivirus software. And it really works. |
03-31-2006, 06:33 | #6 (permalink) |
No Life Poster Join Date: May 2004 Location: A ROUGH ROAD LEADS 2 THE STARS
Member: 66937 Status: Offline Thanks Meter: 5,053 | hello 1. INSTAL NEW DRIVER IMPLMENTED IN NEW UPDATE. 2. CHEAK EITHER HANDSET IS NOT WATER DAMAGE. 3. CHEAK PHONE DONT HAVE ANY SHORTING.... 4. CHEAK CABLE CONNECTER.... 5. REPAIR SUITE..... FROM ADD AN REMOVE.... IF STILL PROBLAM PRESIST SIMPLY REMOVE RJ45- FROM BOX AN PRESS FLASH THEN CONNECT CABLE... PROBLAM SOLVE..... THIS CAN BE NEW UPDATE PROBLAM WILL BE SOLVE IN NEXT & NEW UPDATE ALSO ADDING SOME NEW MODEL'S WHICH WILL BE ON SUPPORT VERY SOON... SARAS WORKING ON IT... 1. 1112 2. 2310 3. 2610 WBR MUNNA WWW.GSMMUNNA.COM |
1st Boot Err: Bad Resp UFSx | tiger700 | HWK | 33 | 07-12-2007 03:15 |
1st boot err: bad resp ufsx | wuyong | HWK | 4 | 03-10-2007 19:00 |
1st Boot Err: Bad Resp UFSx (V3.03 problem, ok with V3.01) | rajSE | HWK | 1 | 11-17-2006 17:45 |
1st Boot Err: Bad Resp UFSx | rajSE | UFS2 + UFS3-Tornadoflasher | 2 | 04-01-2006 22:20 |
1st Boot Err: Bad Resp UFSx | gbrooks3 | n-Box | 3 | 03-15-2005 14:03 |
