Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > UFS2 + UFS3-Tornadoflasher
Old 02-14-2004, 15:46   #1 (permalink)
Member: 7054
1st Boot Err: Bad Resp UPP, 02 FF FF 72
what is this infact ?
eum is ok upp is ok what else to check ?
wbr ficho
Old 02-14-2004, 16:03   #2 (permalink)
isaackenny's Avatar
Member: 9194
Thanks Meter: 3
UPP problem.. tried resolder .. u can tried with griffin the error shoud be FFFF9100
Old 02-14-2004, 17:58   #3 (permalink)
Member: 13808
Thanks Meter: 163
dont check on "autodetect product" and dont check "use ini file setting" after that do CHECK, and if you still have error, then check your cable..
bR
The Following User Says Thank You to essojay For This Useful Post:
Old 02-16-2004, 02:45   #4 (permalink)
Member: 43813
try many times .. watchout ur cable and connection to the phone
Old 02-16-2004, 05:07   #5 (permalink)
locer's Avatar
Member: 8435
Thanks Meter: 7
I have such mistake with UFS2 Tornado on Nokia 5210. I use same cable, Prodigy loads flash 100 %.
Old 02-16-2004, 09:35   #6 (permalink)
Member: 7054
My cable is 100% ok because I have done other 8310 phones with np..
I have new uem and new upp and have changed them again with new uem/Upp just for any case,, again same ****.. If I remove UPP then tornado response 03 00 00 72 ( what means upp not respond ) so in case 02 FF FF 72 upp responds !!! but in manual it is written cant set flash mode.. ( it doenst matter if flash is installed or not.. I test this on some other phoe ) so I measured 32khz if it goes from uem to upp ok I changed hagar and 26mhz also same and I didnt try 13mhz but this isnt important at all as I think
ficho
Old 05-06-2004, 01:04   #7 (permalink)
sergioems's Avatar
Member: 9502
Thanks Meter: 9
did you solve it? and if so how?
Old 07-01-2004, 14:11   #8 (permalink)
Crazy Poster
Member: 31062
Same problem here...
Any solution availble?
Old 07-02-2004, 12:56   #9 (permalink)
BANTUGBRO's Avatar
Member: 43363
Thanks Meter: 2
Plz,Check again ur Cable mate!
WBR,
BANTUGBRO
Old 11-17-2004, 19:30   #10 (permalink)
webmoly's Avatar
Member: 66171
Thanks Meter: 6
5210 flash need
Hi
where can I download 5210 MCU and PPM with Persian or english language ? Its flash files are not listed in UFS support area.
can anyone gimme a link to download them or send them to [email protected] ?
hope to hear soon
have fun
moly
Old 11-18-2004, 17:08   #11 (permalink)
doctorvatson's Avatar
Member: 5889
setup last fia package 03.18
Old 11-18-2004, 17:11   #12 (permalink)
Member: 73037
your phone's upp is damaged or unsoldered
but check all conections with phone too
Old 03-02-2005, 05:52   #13 (permalink)
Member: 65714
Thanks Meter: 17
try to check your flash, or remove your flash, then just check
Old 04-16-2005, 21:26   #14 (permalink)
Member: 18194
Thanks Meter: 7
Got the same problem,
but tried some ui setting before, then check=> Ok.
Old 01-10-2010, 09:28   #15 (permalink)
Member: 472592
Sonork: 100.1664052
Thanks Meter: 152
first of all wash ur fone
then heat on cpu and power
then connect 100% ok
1st Boot Err: Bad Resp UPP, 03 00 00 72 XARiUS UFS2 + UFS3-Tornadoflasher 5 10-05-2011 16:12
1st Boot Err: Bad Resp UPP, 03 00 00 72 (NOKIA 6230.) davoldv UFS2 + UFS3-Tornadoflasher 6 08-15-2010 17:53
twister error 1st Boot Err: Bad Resp UPP, A0 F6 FF 72 ??? nnnm0sad Twisterflasher 1 06-16-2005 12:36
1st Boot Err: Bad Resp UFSx gbrooks3 n-Box 3 03-15-2005 14:03
1st Boot Err: Bad Resp Ufs graca Twisterflasher 2 05-27-2004 12:12
Page generated in 0.38803 seconds with 8 queries
