Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > UFS2 + UFS3-Tornadoflasher
Old 03-09-2005, 06:33   #1 (permalink)
Member: 72851
Thanks Meter: 28
6020 flashing problem
Hii ....I just flash PPM only(Brandnew phone)
I facing this error
1st Boot Ok, DCT4, UPP: 2142
Fl0: 0x01000000-0x01FFFFFF,00EC22F8,Sam K8S2815ET
Algorithm: u_amd.fia
Algorithm Ok, MSID: 84D4E211E999124C16CF8EB334
Decoded MSID: 3E4EBAE9-00D40B6F-A8000000
Encoded FAID: 7120432F-076B076A-578395AA
Area1: 0x01860000-0x01A5FFFF Erased, Time: 00:22
Write Error: hDat 14, at: 0x01860000:08
Process Failed, Repowering Mobile
dctx_i still not supported or else??
Best Regard
Gsm-W
Old 03-09-2005, 18:17   #2 (permalink)
ansartec's Avatar
Member: 26500
Sonork: 100.101633
Thanks Meter: 282
Try to flash again, I think this is bugs in this version.
Old 03-10-2005, 09:18   #3 (permalink)
Member: 72851
Thanks Meter: 28
hope for the next update to solve this problem.
best regard
Gsm-W
Old 03-12-2005, 13:44   #4 (permalink)
Member: 20199
Thanks Meter: 4
hello What cable is use?
Old 03-12-2005, 14:25   #5 (permalink)
Member: 86182
reinstall DCTx & driver can help you, good luck !
Old 03-12-2005, 18:24   #6 (permalink)
ansartec's Avatar
Member: 26500
Sonork: 100.101633
Thanks Meter: 282
cable for 3220 or 7260 is same for 6020.
Old 03-12-2005, 22:11   #7 (permalink)
SPUnlock_SK's Avatar
Member: 13922
Thanks Meter: 334
I get this message sometime when I flash n6230 v526 try on another PC, this help for me
Old 03-13-2005, 03:51   #8 (permalink)
Member: 72851
Thanks Meter: 28
@segsm
@ansartec
3220 cable!!
Best Regard
Gsm-W
Old 03-13-2005, 12:44   #9 (permalink)
Member: 20199
Thanks Meter: 4
@segsm
@ansartec
3220 cable!!
Best Regard
Gsm-W
Thanks I flash Succeed
Old 05-23-2005, 14:18   #10 (permalink)
Member: 3858
Thanks Meter: 2
Hello
I have the same problem! Tryed on pentium 400mgz and duron 750 mgz not working
How you did it?
Old 06-14-2005, 20:06   #11 (permalink)
Member: 58196
Same problem
3220 death try flash!
Same error in the window.
Solution with ufs??
Old 06-14-2005, 20:26   #12 (permalink)
Member: 90236
Thanks Meter: 4
I have a identic problem with 2 pcs of 6020 and i take an other cable from my friend all OK. I think it's cable problem, i may unlock, erase flash with my cable but when i want to write i have a identic communicate. Change cable !!
Old 06-27-2005, 17:05   #13 (permalink)
GamalyGsM's Avatar
Member: 154404
Thanks Meter: 131
iam tried 3220 cable and its work 100:%
Old 06-27-2005, 18:09   #14 (permalink)
Member: 10964
Thanks Meter: 285
@pacoleczo
this is just bad china cable (all cables are china cables ). you'll find a good position and then it will start to flash all 6020.
Old 09-11-2005, 22:17   #15 (permalink)
Member: 145084
Sonork: 100.83885
Thanks Meter: 238
i have he same problem with 6020 v.3.92
Fl0: 0x01000000-0x01FFFFFF,0020882E,St No Name
Algorithm: u_st_i.fia
Algorithm Ok, MSID: 84B7B355CE062DC07AF1D49225
Decoded MSID: 1C15BAE3-009317AC-AD0005BD
Encoded FAID: 795A4358-84E7C26D-34191C39
Erasing: 0x01A60000-0x01E5FFFF ...
Erasing Error: 10, at: 0x01A60000-0x01A7FFFF, 940207, Time: 00:00
6020 flashing problem yandbass Nokia Hardware & Hardware Repair 11 09-02-2007 15:49
6020 flashing problem Alex8392003 Universalbox 8 11-20-2005 00:01
6020 Flash problem june_mobile Nokia Hardware & Hardware Repair 0 10-22-2005 19:22
6020 flashing problem insidebga UFS2 + UFS3-Tornadoflasher 2 05-24-2005 12:05
6020 flashing problem insidebga UFS2 + UFS3-Tornadoflasher 1 05-23-2005 19:19
Page generated in 0.28613 seconds with 10 queries
