03-03-2005, 21:53 | #1 (permalink) |
Freak Poster Join Date: Sep 2004 Location: Paris Age: 47
Member: 82980 Status: Offline Thanks Meter: 23 | 6600 flash error help. 1st Boot Ok, WD2, UPP: 1081 Fl0: 0x00000000-0x007FFFFF,002088C0,St M28W640 Fl1: 0x02000000-0x02FFFFFF,002080C0,St No Name Fl2: 0x04000000-0x047FFFFF,002088C0,St M28W640 Fl3: 0x06000000-0x067FFFFF,002088C0,St M28W640 Algorithm: w3_st_i.fia, w3_cbusb.fia Alg Boot Error: 2 Error Data1: 00000000: 9B 00 04 00 20 00 C0 88 00 00 00 00 02 20 00 C0 .... ........ .. 00000010: 80 00 00 00 00 04 20 00 C0 88 00 00 00 00 06 20 ...... ........ 00000020: 00 C0 88 00 00 00 00 C6 00 00 EA 75 01 00 EA 78 ...........u...x 00000030: 01 00 EA 7B 01 00 EA 7E 00 00 00 00 00 00 00 00 ...{...~........ Error Data2: 00000000: C3 72 00 C0 88 00 00 00 00 02 20 00 C0 80 00 00 .r........ ..... 00000010: 00 00 04 20 00 C0 88 00 00 00 00 06 20 00 C0 88 ... ........ ... 00000020: 00 00 00 00 C6 00 00 EA 75 01 00 EA 78 01 00 EA ........u...x... 00000030: 7B 01 00 EA 7E C3 72 00 00 00 00 00 00 00 00 00 {...~.r......... Before taking screenshot, expand this window ! Process Failed, Repowering Mobile ************************************************** ****** any idea??? tanks |
03-03-2005, 22:35 | #2 (permalink) |
No Life Poster Join Date: Apr 2004 Location: Skopje , Macedonia Age: 40
Member: 61851 Status: Offline Sonork: 100.1604862 Thanks Meter: 117 | br I thik that you should check if the phone has some hardware problems,like mcu or uem.Does it detect the phone?Does the phone power up?If not power up then you should check the mcu and uem are they ok,then you should try to flash the phone.Anyway this also can be a flash error or the ufs can not find the path to the flashfile you are about to put in the phone.Post here about the question I've asked you and will see if I can help you about it. regards |
03-03-2005, 23:49 | #3 (permalink) |
Freak Poster Join Date: Jan 2001 Location: Aveiro, Portugal
Member: 3066 Status: Offline Thanks Meter: 0 | Hi, I had the same problem once, and was Bluetooth hardware problem. If you uncheck the BT enable flashing, it is possible to flash the phone. Try to click in the Rp BT button, it may return an error! Skippy |
03-05-2005, 18:40 | #5 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | Yes.. its hard to identity that which one is bad and need replacement.. Or; 1st boot OK, UPP WD2..etc, but after change the IC Flash still wont flashed. I had once like that. Broken UPP! but it said 1st boot OK.. So, the UPP is ignore the existence of IC Flash.. Try the easiest way first.. it's sometime with very good luck,,,, Regards |
6600 flashing error please help !!! | dapinderjit | Nokia Hardware & Hardware Repair | 5 | 02-09-2009 19:12 |
6600 flashing error with ufs please help | nizoudj | WD2 & APE (Symbian Phones) | 6 | 08-15-2007 09:01 |
6600 flashing error now 6600 dead | kabeermaster25 | Nokia Hardware & Hardware Repair | 25 | 04-08-2006 02:31 |
6600 flashing , Error[BDBDADAD] | usernome | Griffin | 18 | 03-22-2005 11:37 |
6600 Flashing Error! | heiichi | UFS2 + UFS3-Tornadoflasher | 9 | 01-17-2005 16:40 |
