10-30-2004, 12:15 | #1 (permalink) |
No Life Poster Join Date: Oct 2003 Location: MUMBAI Age: 53
Member: 41672 Status: Offline Thanks Meter: 195 | 6600 Init Normal Mode Failed, Fatal Error after flash ufs2 Init Normal Mode Failed, Fatal Error Detected: V 5.27.0 28-06-04 NHL-10 (c) NMP 1st Boot Ok, WD2, UPP: 1081 Fl0: 0x00000000-0x007FFFFF,002088C0,St M28W640 Fl1: 0x02000000-0x027FFFFF,002088C0,St M28W640 Fl2: 0x04000000-0x047FFFFF,002088C0,St M28W640 Fl3: 0x06000000-0x067FFFFF,002088C0,St M28W640 Algorithm: w3_st_i.fia, w3_cbusb.fia Algorithm Ok, MSID: 84EA79D660F7F720FAD214CA7C Decoded MSID: 3E4EBAF7-004CB03F-A9000000 Encoded FAID: B8DFB796-844331A3-1B23971F Area: 0x00000000-0x0000FFFF Erased, Time: 00:00 Area: 0x00010000-0x007FFFFF Erased, Time: 01:04 Area: 0x04000000-0x046FFFFF Erased, Time: 00:55 Area: 0x06000000-0x066BFFFF Erased, Time: 00:59 Area: 0x047C0000-0x047EFFFF Erased, Time: 00:01 BT MCM (21) Image Found: 0x0002DD94 BT MCM Registering Done MCU Flashing Completed, Time: 10:30 Area: 0x00000000-0x0000FFFF Erased, Time: 00:00 Area: 0x02000000-0x0213FFFF Erased, Time: 00:10 PPM Flashing Completed, Time: 00:34 Flashing Completed, Rebooting Mobile Set UI Factory Defaults Ok, Time: 00:04 Set Full Factory Defaults Ok, Time: 00:52 Set Security Ok, Time: 00:00 IMEI: 353777-00-943452-9, ASIC: 5 SimLocks Initialized, 00, Time: 00:02 Init Normal Mode Failed, Fatal Error i have two 6600 same problem whats a problem pls. help me thanks |
Nokia 2600 (RH-59) Init local mode Failed | GRIFFFMAN | UFS2 + UFS3-Tornadoflasher | 15 | 10-24-2010 05:16 |
1600 fleshing ok local mode/test mode ok but normal mode fail | zargar322 | Nokia Hardware & Hardware Repair | 9 | 03-31-2008 16:22 |
3200-6100-6600 inital local mode failure | newmazin | Nokia Hardware & Hardware Repair | 15 | 06-17-2006 01:57 |
Nokia 6670 - Init Local Mode Failed | Hersonsky | Twisterflasher | 1 | 11-13-2005 11:34 |
3100 rh19 init normal mode failed, no sim card | baraka42 | Twisterflasher | 0 | 10-29-2004 10:56 |
