12-13-2004, 21:58 | #1 (permalink) |
Freak Poster Join Date: Dec 2002 Location: UAE Age: 43
Member: 18974 Status: Offline Thanks Meter: 2 | 6600 no open gallary and bt no work plz help see what i do and waht should i do i recived the mobile no power i tried to flash the phone with ufs3 i get this massage 1st Boot Ok, WD2, UPP: 0082 Fl0: 0x00000000-0x007FFFFF,0001267E,Amd 29BDS643HT Fl1: 0x02000000-0x027FFFFF,0001267E,Amd 29BDS643HT Fl2: 0x04000000-0x047FFFFF,0001267E,Amd 29BDS643HT Fl3: 0x06000000-0x067FFFFF,0001267E,Amd 29BDS643HT Algorithm: w2_amd.fia, w2_cbusb.fia Algorithm Ok, MSID: 841E27680CD9010E8BE7DB7EA8 Decoded MSID: 3E4EBAF7-001A75D7-A8000000 Encoded FAID: F1387041-D2B09EB8-C93F8AF1 Cbus Boot Error: 9 Error Data1: 00000000: 00 96 84 1E 27 68 0C D9 01 0E 8B E7 DB 7E A8 67 ....'h.......~.g 00000010: 26 02 26 10 01 04 01 00 7E 26 02 26 10 01 06 01 &.&.....~&.&.... 00000020: 00 7E 26 02 26 10 01 C6 00 00 EA 75 01 00 EA 78 .~&.&......u...x 00000030: 01 00 EA 7B 01 00 EA 9A 00 00 00 00 00 00 00 00 ...{............ Error Data2: 00000000: A3 72 72 7E 26 02 26 10 01 02 01 00 7E 26 02 26 .rr~&.&.....~&.& 00000010: 10 01 04 01 00 7E 26 02 26 10 01 06 01 00 7E 26 .....~&.&.....~& 00000020: 02 26 10 01 C6 00 00 EA 75 01 00 EA 78 01 00 EA .&......u...x... 00000030: 7B 01 00 EA 9A C3 72 00 00 00 00 00 00 00 00 00 {.....r......... Before taking screenshot, expand this window ! Process Failed, Repowering Mobile i remove the bt flashing and flash mobile flashing and open but gallary stop in opening files take 1 minite and give me a masssage "app. closed screensaver" or "app.close media gallary "and bt not work but camera work ok and saving when i tried to open gallary from the camera same massages come "app.close media gallary " i erasse holl flash by eraser files and addresses and try to flash with ufs same error come Cbus Boot Error: 9 Error Data1: with griffin Initializing Phone... Flash configuration: 9B040001007E26022610010201007E26... Error[BDBDADAD] if i skip bt flashing ok before any mobile no oen gallary i change flash no. 2 from the left and uem also i do but come same i change bt kit "the hole ic's" come same no bt flashing i chane the 4 flashes come same i tried softwear i erase hole flash then write pm without product code same also what i can do else thanx regards MelMe |
12-13-2004, 22:54 | #3 (permalink) |
Freak Poster Join Date: May 2003 Age: 48
Member: 29870 Status: Offline Thanks Meter: 24 | @ MELME First change upp and then flash it.If it didn't help you you should change one of flash IC.By the way for more experience plz see this this post : http://forum.gsmhosting.com/vbb/show...=154750&page=2 |
12-14-2004, 18:00 | #6 (permalink) |
No Life Poster Join Date: Mar 2003 Location: Nowhere Age: 44
Member: 25067 Status: Offline Thanks Meter: 81 | i've got 6600 with problem opening image and camera temporary overload too i tried to change all flash ic with no luck i think it absolutely not flash ic faulty, maybe ic ram (i think 100% ic ram) but in my country i cannot buy a new ic ram |
12-15-2004, 02:05 | #8 (permalink) | |
No Life Poster Join Date: Jan 2002 Location: Jordan Age: 46
Member: 8664 Status: Offline Sonork: 100.1573507 Thanks Meter: 56 | Quote:
in most cases CHANGE BLUETOOTH it will work. BR Mansi | |
1202 only open speaker work....plz help | guljee786 | Nokia Hardware & Hardware Repair | 5 | 05-02-2010 07:50 |
v3 ringer and speaker not working plz help | asif_ae | Motorola Hardware Repair | 1 | 06-26-2009 12:37 |
w810i speaker and buzzer don't work,plz help!!! | gsmshare98 | Sony Ericsson Hardware Repair | 1 | 01-29-2008 12:04 |
6600 no open gallary and bt no work plz help | MELME | Nokia Hardware & Hardware Repair | 110 | 07-07-2007 13:45 |
6280 camera problem (operation failed) and Bt don't work | .:bono:. | Nokia Base Band 5 ( BB-5 ) | 5 | 07-13-2006 08:09 |
