Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2003 Location: MUMBAI Age: 43
Member: 41672 Status: Offline Thanks: 45
| 6670 phone start-up failed. contect retailer flashing so many times with Dctx_UFS_1.3k & try to full erase & after flashing pm writing, unlock Set UI Factory Defaults Ok, Time: 00:07 Set Full Factory Defaults Ok, Time: 01:23 Set Software Upgrade Defaults Ok, Time: 00:00 Set Security Ok, Time: 00:00 IMEI: 355023-00-394320-9, ASIC: 5 SimLocks Initialized, Time: 00:12 all ok at last format user area done but same sowing contect retailer pls. help me. thanks shri |
| | #2 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jun 2005 Location: 6 Feet Under Age: 32
Member: 152205 Status: Offline Thanks: 0
| try this way waiting ur replay plz 1. Read PM 2. Erase Flash 3. Mamual Flash > Use INI > Choice RH-67 > CHoice Language. 4. Flash 5. Write PM that u had read 6. Factory Settings 7. Format User Area 8. Unlock *GCM TEAM* |
| | #5 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Nov 2004 Location: 29700A53 - BB PIN
Member: 91045 Status: Offline Sonork: 100.1577222 Thanks: 1,679
| first try formatting ur phone using "RED" "*" and "3" keys if notthing happened try formatting userarea 5,6 times id should definetly work.. |
| | #6 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2002 Location: UK/Espaņa Age: 43
Member: 12578 Status: Offline Thanks: 21
| If you face any of the following problems: 1. Blank screen phone unable to reboot. 2. Phone only able to boot-up to "Nokia" word screen. 3. Install some program but not able to uninstall it after that. 4. Unable to delete unwanted files on C drive. 5. If contact retailer message appears Do a Full phone formatting on your phone as per the steps below, 1. Make sure you have at least 3/4 charge of battery power left. 2. Backup your contacts list and personal files to MMC memory card. 3. Switch-off your phone. 4. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone. Remember, do not let go the 3 press and hold keys until you see a formatting word screen show! 5. After a few minutes when the Full phone formatting completed, your phone should back to original system and factory settting. Problem is solved WBR yeldar |
| | #7 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Aug 2004 Location: Riyadh, K.S.A. Age: 38
Member: 77205 Status: Offline Thanks: 14
| hi, try this.. reheat the flash ic (2) and shake the ic just a little bit.. then flash again and format.. format manual is much better or effective.. |
| | #8 (permalink) | |
| Quote:
how can i find out {ic 1,2,..} thanks pls. show me pic. or diagram if u possible thanks shri | |
| | #10 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2005 Location: underground
Member: 113818 Status: Offline Thanks: 0
| First My 6670 Network Problem,then I Flash New Version And Pm File,after Flash My Lcd Blank. Any Body Help Me? |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| 620 contect retailer | gul-fraz | Samsung Hardware Repair Area | 1 | 02-14-2008 20:24 |
| Nokia 6600 contect retailer service after flash | aukonline | MT-BOX | 3 | 11-21-2007 14:05 |
| 6670 contect retailer | sjawall | WD2 & APE (Symbian Phones) | 5 | 10-02-2006 12:59 |
| 6630 after flash same condition.contect retail condition | aukonline | MT-BOX | 4 | 04-23-2006 23:51 |
| 6600 COntect retailer | paklink | Griffin | 6 | 03-08-2006 01:38 |
