10-30-2004, 17:43 | #1 (permalink) |
Insane Poster Join Date: Oct 2003 Location: Bradford England Age: 50
Member: 41292 Status: Offline Thanks Meter: 0 | 7610 full flash erased Please give me instructions on how to solve this problem. Thanks |
10-30-2004, 18:27 | #2 (permalink) |
No Life Poster Join Date: Aug 2002 Age: 57
Member: 14515 Status: Offline Sonork: 100.77248 Thanks Meter: 15 | Just choose the correct MCU + PPM file then push flash. After flash push FORMAT USER AREA. After it read the phone. If the parameters are ok then put a SIM into it and try. If you erased lock area , RF parameters then you have to upload a pm file to your phone and unlock it. BR Roy |
10-30-2004, 20:40 | #3 (permalink) |
Member: 41292 Status: Offline Thanks Meter: 0 | 7610 dead thanks for the reply, I have flashed the mcu & ppm then format user area but get this message user area format failed 00000000: 00 00 00 00 00 00 00 00 What am I doing wrong? Regards |
10-30-2004, 20:50 | #4 (permalink) |
Member: 14515 Status: Offline Sonork: 100.77248 Thanks Meter: 15 | Try to format user area from the phone keyboard. Just put a battery into the phone. Push and hold down 'GREEN' + '3' + '*' buttons then switch on the phone. Try it until you'll see 'Formatting...' on the display. BR Roy |
10-31-2004, 13:50 | #7 (permalink) |
Member: 41292 Status: Offline Thanks Meter: 0 | at last getting somewhere Thanks again, managed to flash and format the handset but all I get now is flashing nokia sign every 30 seconds or so, I have tried to start in normal mode after formating user area but always fails. Any ideas? Thanks |
10-31-2004, 18:27 | #9 (permalink) |
Member: 14515 Status: Offline Sonork: 100.77248 Thanks Meter: 15 | 3 different Flash chips are in the 7610. Erase the next areas: 00000000-00FFFFFF 02000000-02FFFFFF 04000000-047FFFFF After these flash areas that @xileen2k said. BR Roy |
10-31-2004, 19:28 | #10 (permalink) |
Member: 41292 Status: Offline Thanks Meter: 0 | 7610 Erased those 3 flashes & flashed as required, then unlocked no problems, then formated user area, when I tryed to boot in normal mode got message cant init normal mode no sim card, even though sim card is in phone. after that switched phone on with sim present to see this message: app.closed phone |
11-01-2004, 11:24 | #11 (permalink) |
Member: 41292 Status: Offline Thanks Meter: 0 | 7610 app.closed phone 7610 -------------------------------------------------------------------------------- Erased those 3 flashes & flashed as required, then unlocked no problems, then formated user area, when I tryed to boot in normal mode got message cant init normal mode no sim card, even though sim card is in phone. after that switched phone on with sim present to see this message: app.closed phone |
11-01-2004, 20:25 | #12 (permalink) |
Member: 41292 Status: Offline Thanks Meter: 0 | help please Erased those 3 flashes & flashed as required, then unlocked no problems, then formated user area, when I tryed to boot in normal mode got message cant init normal mode no sim card, even though sim card is in phone. after that switched phone on with sim present to see this message: app.closed phone |
Vodafone 332 FM unsuported. Link with full flash | stargsm_ro | FuriousGold | 1 | 03-29-2010 19:54 |
7610 full flash???? | Gsm Lab | MT-BOX | 4 | 05-25-2006 12:44 |
is there a soft that repairs BE5 with full flash erased ? | majid | Alcatel & TCL Old Models | 3 | 08-07-2002 03:14 |
