12-09-2004, 04:04 | #1 (permalink) |
No Life Poster Join Date: Jan 2002 Location: Jordan Age: 46
Member: 8664 Status: Offline Sonork: 100.1573507 Thanks Meter: 56 | 9110 on UFS-3 did any1 flash 9110 using ufs-3? because i tried so many times and i could not flash it, i do not know where is the prob. thanks in advance Mansi |
12-10-2004, 11:24 | #3 (permalink) |
No Life Poster Join Date: Jun 2002 Location: CTSA Age: 46
Member: 12660 Status: Offline Thanks Meter: 7 | Hi mansi search forum gbluez is correct remove the sticker where the battery goes and you will see contact points and you short two of them out and it will show link enabled or something to that effect on the PDA lcd Regards D. |
12-13-2004, 00:17 | #4 (permalink) |
Member: 8664 Status: Offline Sonork: 100.1573507 Thanks Meter: 56 | thank you for replays...here what i understod.. a-remover sticker which is under the battery place. b-find 2 pinouts c- short both points togather d- place battery e-try to flash the phone i hope i understod right, i will try and post later. thanks Mansi |
12-13-2004, 01:13 | #5 (permalink) |
Administrator Join Date: Jul 2002 Location: E G Y P T Age: 38
Member: 14178 Status: Offline Thanks Meter: 8,862 | guys even with the PDA or the phone part short you can't flash 9110 useing any tool Twister/UFS,Prodigy,JAF,Griffin only the old cable with KNOK flasher , phoenix black box and nokia orignal tools Last edited by Evil Neo; 12-13-2004 at 01:29. |
12-13-2004, 13:51 | #7 (permalink) | |
Member: 8664 Status: Offline Sonork: 100.1573507 Thanks Meter: 56 | Quote:
yes you can do that, but you will flash phone part only, PDA will not be flashed. Mansi | |
12-13-2004, 18:50 | #8 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | THis is the solustion with Dejan Flasher, find your self the equivalen with UFS or other flasher. Backup your 9110. Make sure you have backup your 9110. Make sure you made sure you have backup your 9110. You'll need these two zip files 704mmc.zip = PDA update files cmt_601.zip= phone flash files You may also want to download winimage, This will enable you to extract files from uk704mmc.img (inside 704mmc.zip) How TO : ************************ ****Flash phone PART**** ************************ You'll Need : MBUS cable Flasher Cable 1)remove sicker under battery'Use Only Nokia specified Li-ion Battery' hold phone up right pin 1 is to the left. connect pin 15-16. Connect battery. On screen (top left in small text) should say 'relink mode enabled' can now flash as 9110. 2)use wt2dejan or any flasher capable - convert rae2n06.010 = MCU rae2n06.01a = PPM - A - ENGLISH N.B. files are inside cmt_601.zip. 3)Using 'Nokia Flasher v1.00b' by Dejan Kaljevic write converted MCU @ 0x00200000 and then write converted PPM @ 0x002f0000 4)use eeprom tools - Bottom left button 'Update AuthorityID'. 5)Disconnect pin 15-16. 6)All should be done now done *********************** ****Update PDA Part**** *********************** You'll Need 4MB (or more) MMC and some knowledge of how to use DOS would help. If you don't have DOS Prompt Launcher by Dave Chapman Then you'll have to get it and install it to the communicator's memory 1)Inside 704mmc.zip you'll find uk704mmc.img This is a 4MB disk image. using winimage open uk704mmc.img and extract all the files. Copy the extracted files onto a MMC. (If not already put MMC into your 9110) The files are: autoexec.bat - 27 bytes command.com - 81,130 bytes dos.sys - 40,198 bytes spock.hdr - 20 bytes spock.lzs - 3,577,796 bytes swupdate.exe - 35,186 bytes 2)remove sicker under battery'Use Only Nokia specified Li-ion Battery' hold phone up right pin 1 is to the left. connect pin 1-4. 3)Run DOS Prompt and find the files you copied to your mmc run swupdate.exe YOU should see a a bar process bar along the top. This process should only take about 2mins. N.B MMC is Drive A If you used PC Suite to copy the files to your mmc theyll be under nokia\document\mmc 4)Once finished remove PIN 1 - 4. 5)You're done ************** ****Extras**** ************** Remove battery then press and hold 1)To format - shift + tab + f 2)Check drive for errors - shift + tab + left 3)Delete state files - shift + tab + right 4)Debugging!! - shift + d + b 5)Debugging!! - shift + d + o then connect battery. REGARDS - May help |
01-27-2006, 13:23 | #9 (permalink) | |
Crazy Poster Join Date: Dec 2004 Age: 53
Member: 99064 Status: Offline Thanks Meter: 5 | Quote:
how update firmware on ufs-3 | riyazzoon | UFS2 + UFS3-Tornadoflasher | 7 | 03-27-2010 13:30 |
What the USB connectors for ?on UFS-3 | fadi3 | UFS2 + UFS3-Tornadoflasher | 4 | 05-28-2005 19:21 |
9110 and UFS-3 | gsm2000 | UFS2 + UFS3-Tornadoflasher | 0 | 07-28-2004 13:27 |
1st boot error on UFS-3 | sloper | UFS2 + UFS3-Tornadoflasher | 8 | 05-05-2004 01:57 |
Flashing N-Gage on UFS-3 | fonedoctorjnr | UFS2 + UFS3-Tornadoflasher | 1 | 04-29-2004 21:25 |
