Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > UFS2 + UFS3-Tornadoflasher
Old 02-06-2005, 13:26   #1 (permalink)
Anno's Avatar
Member: 8360
Thanks Meter: 4
Arrow 9500 Phone lock. How clear ?
I use Dctx_Ufs_13h.exe software to clear phone lock. But no help.
Reset User lock not work for me . After all UI options reset lock stay in phone.
I need flash phone ?
I have this files:
RA2_4441.352
RA2n4441.c01
RA2n4441.u01
RA2nxxxx.P01.pp
What files i must use in:
MCU..
PPM..
CNT..
UFS can flash 9500 phone without problems ?
*Thanks about help
Old 02-06-2005, 15:54   #2 (permalink)
Anno's Avatar
Member: 8360
Thanks Meter: 4
thanks about help
Old 02-12-2005, 09:35   #3 (permalink)
Member: 67176
Thanks Meter: 87
after reset user lock
type full factory defaults
Old 02-12-2005, 10:25   #4 (permalink)
.::Gsmdenis::.'s Avatar
Member: 79315
Thanks Meter: 6,024
yes,try to do this step,and then post the result here.
Old 02-12-2005, 10:33   #5 (permalink)
Member: 17998
Thanks Meter: 2
try this: power on phone, tick init simlocks.
Old 02-12-2005, 10:36   #6 (permalink)
Member: 79315
Thanks Meter: 6,024
realy! let me try that!
Old 02-12-2005, 10:38   #7 (permalink)
Member: 17998
Thanks Meter: 2
yup unlocked 3 9500 using ufs
Old 02-12-2005, 10:53   #8 (permalink)
Member: 79315
Thanks Meter: 6,024
but just now i try that ,all of that working 100%
Old 02-12-2005, 22:11   #9 (permalink)
Member: 16036
Thanks Meter: 5
hi
no1 really ANYSWERED anno ? about files to select to flash phone n weather at this point its safe to flash the phone
i have also tryed to factory reset n default user code
BUT failed
i get 2nd boot arror
any help advice will be appreciated
thanks alot
Old 02-12-2005, 22:38   #10 (permalink)
Member: 45682
Thanks Meter: 54
hi
to resset user code for 9500 need black box or jaf only
br
Old 02-13-2005, 02:45   #11 (permalink)
Member: 92755
I have this files:
RA2_4441.352
RA2n4441.c01
RA2n4441.u01
RA2nxxxx.P01.pp
MCU..
PPM..
CNT..
*Thanks about help
folow my steps it may help u
1-init sim locks
2-full factory defaults
3-change into normal mode
4-format user area
try again if error occured
if no result try to flash it
1-ur mcu r (RA2n4441.c01)
2-ur ppm r(RA2n4441.l03)
3-ur cnt r(RA2n4441.u03)
Old 02-13-2005, 11:05   #12 (permalink)
Member: 16036
Thanks Meter: 5
hi man
flashing problem error
when i select
1-ur mcu r (RA2n4441.c01) <<<-- i get error"NOTHING TO FLASH"
if i select Ra2_4441.352 i get this error then :
1st Boot Ok, ORCA, UPP: 1130
Fl0: 0x01000000-0x013FFFFF,00012A7E,Amd 29BDS320
Algorithm: m_amd.fia
Algorithm Ok, MSID: 842FEE85175F8156E18B967A02
Decoded MSID: 3E4EBAE9-005DA9C0-A8000000
Encoded FAID: 52CFD751-D19E4C13-A12C0CF9
Erasing: 0x01000000-0x0100FFFF ...
Erasing Error: 10, at: 0x01000000-0x0100FFFF, 94050F, Time: 00:12
Process Failed, Repowering Mobile
any idea what to do next
thanks alot
Old 02-13-2005, 11:41   #13 (permalink)
Anno's Avatar
Member: 8360
Thanks Meter: 4
STOMATELA : "after reset user lock
type full factory defaults "
No helped for me, phone lock stay in phone
I can't unlock phone code with ufs without flash firmware update.
Old 02-13-2005, 12:01   #14 (permalink)
KARAMAT's Avatar
Member: 51609
Thanks Meter: 6
@ mohammed
ufs not support flashing for 9500
only jaf or pbb
Old 02-13-2005, 12:13   #15 (permalink)
Alim Hape's Avatar
Member: 43548
Thanks Meter: 2,192
Yes UFS only support Partial Flashing 9500, not PDA part.
Also the initSimlocks & Reset UserLock (on some versions) with UFS cant Reset the security code...
@ anno
Please Try this...
Read PM area start 20 to 40...
Open PM Files using notepad...
Find Record /Section 35, key 0...
U will get 7 bytes-->the defaults : 31323334350000
Just remove the chr 3, and u'll get: 123450000
the security code for this the first 5 digit--> 12345
Tested 100% working by me on some DCT4 & WD2 phone..
Please try it, post ur Result here...
lg ke750(*****) phone lock how removed arunamobile ULT PRO 5 07-03-2008 13:44
k610i phone lock how ? patric Cruiser Suite 3 03-09-2007 03:17
Toshiba Phone Lock! How to Disable? theonlyallan FuriousGold 3 07-31-2006 11:45
sgh2400 with phone lock .. how repair ? Kilowat VLSI, Conexant, Skyworks and Old Models 3 02-05-2002 23:21
Page generated in 0.28420 seconds with 9 queries
