03-06-2013, 15:54 | #1 (permalink) |
Junior Member Join Date: Jan 2010
Member: 1214236 Status: Offline Sonork: stoledo043 Thanks Meter: 4 | C6-01 dead after flash with UFS - 3 I downloaded the last version again, with the phone product code, and flashed it again, but still the same. I also tried different firmwares of the last version downloaded from navifirm, and the last version from your support for this RM, but nothing worked, still the same problem. Any suggestions / solution for this? Thanks in advance. |
03-06-2013, 19:29 | #3 (permalink) |
Member: 1214236 Status: Offline Sonork: stoledo043 Thanks Meter: 4 | better but not solved I flashed using infinity with last version as you said. Now the phone starts normally but it does not have IMEI number. I flashed by usb, so I coud not backup rpl and pm before flash (I dont have this fbus cable or pinout), can this be the cause of this new problem? In any case, is there a solution for this? Thanks. |
