Drivers UFS-2 => UFS-3 Hello, I've got a question about drivers for UFS-3, i've lost my cd with those drivers, and i obtain another drivers, and now when installing ufs (i have UFS-3) the computer see it as "UFS2 Device, (c) SarasSoft". Maybe i'm wrong but i think the first time with good drivers it was installed as UFS3(...) Is it a problem, or normal? |
1 Attachment(s) download from atash and keepit in to hdd |
i have ufs3 and in system say twister box lol |
Thank you all, unfortunately those drivers are older then i have... But if it works even as twister i will not to improve it :-) |
Regards Mackie |
hy men ,i want just to ask y how to upgread my ufs2,if it's possible.thank y. |
Same - i have UFS3.gold and it detect it as TWISTER hehe funnny :D |
I Think All SarasSoft Series Box are same. It have same Device firmware And it will work with Any SarasSoft Series driver. If u install Twister driver, PC will detected as Twister If u install NBOX driver, PC will detected as NBOX, Etc.... But Software will detect it as UFSx SarasSoft with Each SN. Also There is 2 Option about S/N. 1 stored in USB Eeprom, 1 on Device Firmware <-Must Match. Br, |
Regards Mackie |
sara's boxes can be detected as any series saras box i've had to re-install my ufs box several times after formatting i've had it detected as twister, ufsx and ufs2 |
No, the difference between ufs2 and ufs3 is... UFS-3 HAS BUILT-IN USB HUB.Because of it mototools for ufs from www.p2k.com.ua cannot be used with ufs-2 it can only be used with ufs-3... |
Yes that's true it is almoust the same box...but if you want to use new software and updates and your box is original you can do it....just contact your reseller and everything will be OK.... Regards Mackie |
Thanks For Good Driver |
Hello guys, I just bought UFS-4 FLASHER but is not working on even setup 3.0 up to setup 3.03 !!! always have an error "Unexpected Exception: BOX_AUTH_ERROR: 51 " Please share, Thanks and best regards, Jham |
