03-02-2005, 13:21 | #1 (permalink) |
Freak Poster Join Date: Mar 2005 Age: 48
Member: 122265 Status: Offline Thanks Meter: 10 | Drivers UFS-2 => UFS-3 I've got a question about drivers for UFS-3, i've lost my cd with those drivers, and i obtain another drivers, and now when installing ufs (i have UFS-3) the computer see it as "UFS2 Device, (c) SarasSoft". Maybe i'm wrong but i think the first time with good drivers it was installed as UFS3(...) Is it a problem, or normal? |
The Following 8 Users Say Thank You to matyjasz For This Useful Post: |
03-07-2005, 10:27 | #4 (permalink) |
Member: 122265 Status: Offline Thanks Meter: 10 | Thank you all, unfortunately those drivers are older then i have... But if it works even as twister i will not to improve it :-) |
The Following 2 Users Say Thank You to matyjasz For This Useful Post: |
03-07-2005, 10:40 | #5 (permalink) | |
No Life Poster Join Date: Jan 2003 Location: Prijepolje-Durmitor, Serbia And Montenegro Age: 46
Member: 19987 Status: Offline Thanks Meter: 27 | Quote:
Regards Mackie | |
The Following 2 Users Say Thank You to MACKIE For This Useful Post: |
05-23-2005, 18:49 | #7 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Poland Age: 34
Member: 117496 Status: Offline Sonork: 100.83919 Thanks Meter: 22,689 | Same - i have UFS3.gold and it detect it as TWISTER hehe funnny |
The Following 2 Users Say Thank You to karwos For This Useful Post: |
05-23-2005, 19:54 | #8 (permalink) |
No Life Poster Join Date: Nov 2003 Location: 00000000h Age: 42
Member: 43548 Status: Offline Thanks Meter: 2,192 | I Think All SarasSoft Series Box are same. It have same Device firmware And it will work with Any SarasSoft Series driver. If u install Twister driver, PC will detected as Twister If u install NBOX driver, PC will detected as NBOX, Etc.... But Software will detect it as UFSx SarasSoft with Each SN. Also There is 2 Option about S/N. 1 stored in USB Eeprom, 1 on Device Firmware <-Must Match. Br, |
The Following 2 Users Say Thank You to Alim Hape For This Useful Post: |
05-23-2005, 23:27 | #9 (permalink) | |
Regards Mackie | |
05-24-2005, 00:19 | #10 (permalink) |
No Life Poster Join Date: Aug 2003 Location: Toronto, Canada Age: 37
Member: 37276 Status: Offline Thanks Meter: 29 | sara's boxes can be detected as any series saras box i've had to re-install my ufs box several times after formatting i've had it detected as twister, ufsx and ufs2 |
The Following 2 Users Say Thank You to fuzionGSM For This Useful Post: |
05-24-2005, 11:00 | #11 (permalink) |
No Life Poster Join Date: Jun 2004 Location: Azerbaijan Age: 38
Member: 68498 Status: Offline Thanks Meter: 152 | No, the difference between ufs2 and ufs3 is... UFS-3 HAS BUILT-IN USB HUB.Because of it mototools for ufs from www.p2k.com.ua cannot be used with ufs-2 it can only be used with ufs-3... |
The Following 3 Users Say Thank You to systemworm For This Useful Post: |
05-24-2005, 12:40 | #12 (permalink) |
Member: 19987 Status: Offline Thanks Meter: 27 | Yes that's true it is almoust the same box...but if you want to use new software and updates and your box is original you can do it....just contact your reseller and everything will be OK.... Regards Mackie |
12-21-2005, 03:20 | #13 (permalink) | |
No Life Poster Join Date: May 2005 Location: Croatia Age: 42
Member: 144433 Status: Offline Thanks Meter: 49 | Quote:
The Following 2 Users Say Thank You to Inovator For This Useful Post: |
03-29-2007, 15:03 | #15 (permalink) |
Freak Poster Join Date: Jan 2004 Location: Georgia Age: 51
Member: 48366 Status: Offline Thanks Meter: 30 | Hello guys, I just bought UFS-4 FLASHER but is not working on even setup 3.0 up to setup 3.03 !!! always have an error "Unexpected Exception: BOX_AUTH_ERROR: 51 " Please share, Thanks and best regards, Jham |
The Following 3 Users Say Thank You to jham For This Useful Post: |
I neeeeed NCDS 2.0!!!! plzz!!!! | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 02-27-2022 22:12 |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
Need info for unliocking 2 lock (with pic microprocesors) | Tomas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-26-1999 01:00 |
