03-26-2005, 12:06 | #1 (permalink) |
Freak Poster Join Date: Mar 2005 Age: 48
Member: 122265 Status: Offline Thanks Meter: 10 | Error 10 while trying to flash nokia. One of possible solutions I frequently read about impossibility flashig nokia phones, and i had a similar problem. Last time yesterday with 3100, but with 6610, 6610i, 1100 too (by now dct4 generally). Screen (when trying to flash) looks like this : Detected: V 4.10 08-10-04 RM-37 (c) Nokia. 1st Boot Ok, DCT4, UPP: 1120 Fl0: 0x01000000-0x01FFFFFF,00EC22F8,Sam K8S2815ET Algorithm: u_amd.fia Algorithm Ok, MSID: 845BA974475443707EB50C5349 Decoded MSID: 82A9BAE9-0092361E-AA000000 Encoded FAID: 85230C2C-3CE5D4B8-C103F506 Erasing: 0x01000000-0x0100FFFF ... Erasing Error: 10, at: 0x01000000-0x0100FFFF, 940207, Time: 00:00 Process Failed, Repowering Mobile manually erasing given address is impossible too. I read forum dedicated to other boxes and found similar problem's solution. To solve this problem with tornado you have to uninstall flash update from control panel/add remove progs., then manually remove ALL files and directories from C:\Program Files\Nokia\Phoenix\Flash, then install flash update again. Curiously enough sometimes better to install older flash updt (ie. 3.18 or even older if necessary, each time removing all files from mentioned directory) - this operation just changes ALL .fia files - that's the solution Of course i'm awake it is not one and only one solution, and probably it is not new, but it helped me and i hope it helps somebody else. respect for all Last edited by matyjasz; 03-26-2005 at 12:29. |
many error codes while trying to unlock SE k510a | stinkiest | TOTAL MultiServer | 0 | 04-30-2007 03:01 |
error message while trying to unlock 3390 with ufs-3 | cellrepairus | UFS2 + UFS3-Tornadoflasher | 0 | 04-15-2006 14:28 |
Z7 not power on. While trying to flash "Download Failed" error | sat | Sony | 0 | 02-17-2003 15:19 |
