10-06-2006, 01:52 | #2 (permalink) |
Freak Poster Join Date: Mar 2004 Age: 47
Member: 57502 Status: Offline Thanks Meter: 2 | Try using UFS, set speed to "NORMAL", and initiate to "LOCAL MODE", wait until Local Mode is initiated OK. Then write PM... If still failed, try to format user area first. Hopefully it can work. Good luck, |
10-06-2006, 02:00 | #3 (permalink) | |
Freak Poster Join Date: Feb 2005 Location: underground
Member: 113818 Status: Offline Thanks Meter: 29 | Quote:
TRY FORMAT USER AREA (FAILED) FLASH MCU AND PPM SUCCESFULL TQ | |
10-06-2006, 02:43 | #5 (permalink) | |
SCANNING OPERATING MODE....... Init Normal Mode Failed, Fatal Error SIR,IF SCANNING OPERATING MODE FAILED I CAN'T WRITE PM. TQ | |
10-06-2006, 02:52 | #6 (permalink) |
Member: 57502 Status: Offline Thanks Meter: 2 | I don't think we can write pm in normal mode. You have to change it in local mode, but speed must be set to normal. So try to set the speed to normal and set to local mode, you have an option beside UI SETTINGS. Then if phone is iniated to Local Mode = OK, you can write pm file. If still failed, try to check the IMEI#, maybe the IMEI is corrupted. thks, |
Failed to write imei..????? | sky_finder | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-30-2010 15:45 |
whats the error -> Failed to Write PM -> Access violation at address 005AE2F5 | Y.P.Y | Cyclonebox | 6 | 03-09-2010 22:12 |
!!![+] 100% SOLUTION - Failed to Write PM -> Access violation [+]!!! | Y.P.Y | Cyclonebox | 0 | 03-09-2010 11:28 |
n96 Failed to write PM block: 308 | mohitgsm | Universalbox | 8 | 03-27-2009 10:23 |
N75 fails to write PM through USB cable ??? | masterANDmind | MT-BOX | 3 | 09-21-2007 10:01 |
