Free Atmega8 & Atmega128 Programmer 10000000% 4 Attachment(s) To All Who Have There Ufsx Boxes Dead Now Atmega Can Be Easly Reprogammed Again Tested Working 100% F For Who Have Old Ufs2 Big Boxes No Need For All (r)s Just Connect To Pin In The Back Of The Box But For How Have Ufs3 U Need This (r)s To Be Installed Regarding Atmega128 Is Not Tested Yet But I Think It Will Work 2 Software Needed "ponyprog" Schematic Is Attached Have A Fun With No More Problems With Ufsx Boxes Regards |
thanks FARFAR |
thank you Thank you very much. |
Ponyprog Link |
@farfar can u explain briefly i am not understand what u explain |
- any body hwo has ufs2 dead he dont need to put resistor becouse the box already has resistor on it - any body with ufs3 or boxes without resistor connected to the pins in the back of the ufs3 box resister is needed - after connecting the pins with the cables run ponyprog and do 1 - go to setup and chose parallel and avr isp api then ok 2 - form setup menu press calibration to calibrate the programmer with ur pc 3 - select avr and atmega8 from the 2 comoboxes 4 press erase all the device 5 file->open program flash file 6- file->open data eeprom file both r atached 7- press write device button 8 you have to set the security bits by pressing the security bit button after programming completed remove the parallel programmer from the box now your box is alive again |
Can you post working config *.jed file for Xilinx 3032? |
farfar can you give me something for 18f452?do you have something simular like this one,I need to repair my prodigy,thanks regards |
Thank you very much |
atmel 1 Attachment(s) If someone is interested, here iz atmel serial programmer & support for programming...... |
"farfar can you give me something for 18f452?do you have something simular like this one,I need to repair my prodigy,thanks" There are many PIC programer availble free on the net, use the google |
10x @farfar and happy new year and best regards |
FARFAR Thanks for reply, but did test this file? http://forum.gsmhosting.com/vbb/showthread.php?t=141767 For me not working, Atmega is programming and reading fine thru xilinx, but there is no communication with phone. |
Thank you Thank you very much |
