03-02-2014, 10:16 | #31 (permalink) |
Moderator Join Date: Mar 2011 Location: metasploit Age: 31
Member: 1537689 Status: Offline Sonork: 100.1669550 Thanks Meter: 2,219 | |
The Following User Says Thank You to gsm mithun roy For This Useful Post: |
03-02-2014, 13:30 | #33 (permalink) |
Junior Member Join Date: Oct 2007 Location: 33
Member: 621974 Status: Offline Sonork: 3 Thanks Meter: 0 | ****ing trash ufs team wee need solution RIP BOX update panel useless... i have original box and original hwk and this **** panel stuck my works where is our supports ? |
03-02-2014, 14:50 | #34 (permalink) |
No Life Poster Join Date: Dec 2013 Location: India
Member: 2082450 Status: Offline Thanks Meter: 1,454 | Here is the solution. Please again update the box through hwk suite. After successful update, click on registy backup and save the key. When this problem again arise, just double click on the key and no need to update again. |
03-03-2014, 06:21 | #35 (permalink) |
Member: 1537689 Status: Offline Sonork: 100.1669550 Thanks Meter: 2,219 | download ufs hwk setup v02.03.00.04 january 2014 update dear all of my gsm friend HWK new update panel v02.03.00.04 released on jan 2014 any old panel won't work all old panel support off you must need to use latest panel downlod latest panel and follow ins...... DOWNLOD 1. Uninstall ALL previous versions, you MUST uninstall HWK Suite BEFORE trying to uninstall HWK Support Suite Setup. 2. Install UFSx Support Suite Setup 3. Connect your UFSx+HWK before running the UFSx Control Panel 4. Run UFSx Control Panel 5. Switch to the "Hardware" Tab 6. If you only have one UFSx connected it will be selected 7. Click "Check Box" 8. Click "Update Box" 9. Click "Check Box" - Make sure "Box Status" = "True" or "Bad Software" and "Server Status" = "Support Ok", before proceeding 10. Switch to the "Software" Tab 11. Amend "Application Install Path" and/or "Nokia Install Path", if required. 12. Click "Check Server" 13. Click "Install" |
09-29-2014, 08:17 | #42 (permalink) |
Banned Join Date: Jan 2013
Member: 1872885 Status: Offline Sonork: 562112 Thanks Meter: 1 | help me...............7BDAE4E0426000C8 NOT AUTHORISED: 17, FE, Update Box App: UFSx (HWK) Control Panel v 2.3.0.6 by SarasSoft CPU: GenuineIntel Platform: Windows NT 6.1 (Build 7601 Service Pack 1) Versions: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.0.0 C:\Program Files C:\Program Files\Common Files Nokia Path not Found, Set to: C:\Program Files\Nokia\Phoenix Last Server Update: 2014/08/22 Active Panel Version: 2.3.0.6 Box: 1 Location: 1057 Serial: 72125 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 72125 HID: 7BDAE4E0426000C8, HWK: A1.04-PRO1 HWK: 7BDAE4E0426000C8 NOT AUTHORISED: 17, FE, Update Box Your IP: 59.152.107.190 Support: Account Ok REST: Ok UFSx: UFS3 SarasSoft, USB S/N: 72125 NVML: Ok BOOT: UFxBoot V2.2 (c) SarasSoft 2003. CORE: UFS_USB V2.8 (c) SarasSoft 2007. SERN: 72125 LIC5: True BOXK: 1 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 72125 HID: 7BDAE4E0426000C8, HWK: A1.04-PRO1 HWK: 7BDAE4E0426000C8 NOT AUTHORISED: 17, FE, Update Box |
01-09-2017, 06:43 | #43 (permalink) |
Junior Member Join Date: Dec 2016 Location: chittagong, banglash
Member: 2661504 Status: Offline Sonork: 100.650600 Thanks Meter: 0 | use repare tool to update. than use UFS_PANEL_2.3.0.7 By nokiafirmware24.********.com update. than click check box. than in software page click check server and in install. |
