04-11-2009, 14:48 | #3 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Under Blue
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | Hi! I just fix same problem with UFS by that way: Setup HWK_Suite_Setup_v02.06.000 after updating got «Box_Auth_Error: 20» 1. Connect box, run UpdateClient.exe > Update UFS Firmware open Req.fbi UpdateClient ask open file –«*box number*.fbi» Give*.* in next string and select Req.fbi Got massage -- UFSx Device: UFS2 SarasSoft, USB S/N: **** -- Target Id : 62 CF 1 10 -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003. -- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007. -- UFSx S/N :***** -- Features : 00000001 -- Licence 5 : True -- UFSx Vendor: TORNADO -- HWK ID : A1.04-****** -- HWK Status : 1, DL: 0 -- Request file generated: "box number.req" Save one. 2.Start ufs3tools269b Open in FBI Calculator "box number.req",calculate "box number.fbi".Save one too.Close ufs3tools269b. Start UpdateClient.exe > Update UFS Firmware againe.Select "box number.fbi" and start update UFS Firmware. Now my box is working. You must do this way.Ur problem will be solved |
04-11-2009, 14:50 | #4 (permalink) |
09-03-2010, 19:16 | #5 (permalink) |
Insane Poster Join Date: May 2009 Location: north india,,, himachal
Member: 1032503 Status: Offline Thanks Meter: 16 | For Box Authorisation Error :20/32 1st download Req.fbi file from Support Site. Then go to updateclient-----update ufsfirmware and select Req.fbi file. It will generate "serial no.Fbi file in C:\Program Files\SarasSoft\UFS\UpdateClient Next download ufs3tools269b.zip from internet. here is url (ufs3tools269b.zip - 4shared.com - online file sharing and storage - download) then open the software and connect ufs. after that click connect. then click on FBI calculator. ( it will create Req.fbi file ) after that again go to updateclient-----update ufsfirmware and select Req.fbi wait 2 min n see it works 100% |
The Following User Says Thank You to naughtybaba For This Useful Post: |
UFS3 problem?? | Kot | UFS2 + UFS3-Tornadoflasher | 3 | 12-07-2007 13:42 |
ufs3 problem | charles njoroge | UFS2 + UFS3-Tornadoflasher | 3 | 09-07-2005 08:13 |
Ufs3 Probleme With D500 - A500 | THE-MAXIMUS | UFS2 + UFS3-Tornadoflasher | 0 | 05-14-2005 13:47 |
ufs3 problem...dct1.3d bug...??? | stanner_austin | UFS2 + UFS3-Tornadoflasher | 3 | 09-19-2004 14:12 |
UFS3 problem | TITO | UFS2 + UFS3-Tornadoflasher | 3 | 06-11-2004 07:02 |
