Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2010
Member: 1306306 Status: Offline Sonork: 240888 Thanks Meter: 33 | ![]() App: UFSx (HWK) Control Panel v 2.3.0.2 by SarasSoft Box: 1 Location: 273 Serial: -xx UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: -xx HID: -xx, HWK: A1.04-PRO1 LIC: True None Authorised Copy of Software Detected, Reinstall HWK: NOT AUTHORISED, Update Box Bad IX: AB11 Failed: 102 Your IP: -xx Support: Account Ok Something Wrong, Try to Use [Update Box] Box: 1 Location: 273 Serial: -xx UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: -xx HID: -xx, HWK: A1.04-PRO1 LIC: True Your IP: -xx Support: Account Ok REST: Ok UFSx: UFS3 SarasSoft, USB S/N: -xx NVML: Ok BOOT: UFxBoot V2.2 (c) SarasSoft 2003. CORE: UFS_USB V2.8 (c) SarasSoft 2007. SERN: -xx LIC5: True BOXK: 0 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: -xx HID: -xx, HWK: A1.04-PRO1 LIC: True Authentication stage error: Error: Server returned unrecognized reply! Are you using latest client software version? then I tried to go to the software tab and then Check Server it says like this .. None of Boxes Selected or Active Use [Check Box] in the Hardware Page or this Last Server Update: 20013/08/21 Not Active Anymore ! For new use this link: Sarunasoftware Support Area -> Message from system No New Items to Install please help thank you... |
The Following 2 Users Say Thank You to alanic For This Useful Post: |
![]() | #3 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2009 Location: Root tunnel Age: 30
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 536 | Click update box and re install support suite.. And if you are on slow connection than try once to manage to install whole UFS suite at once and than like me ![]() |
![]() | #4 (permalink) | |
Member: 1306306 Status: Offline Sonork: 240888 Thanks Meter: 33 | Quote:
Box: 1 Location: 273 Serial: -xx UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: -xx HID: -xx, HWK: A1.04-PRO1 LIC: True Your IP: -xx Support: Account Ok REST: Ok UFSx: UFS3 SarasSoft, USB S/N: -xx NVML: Ok BOOT: UFxBoot V2.2 (c) SarasSoft 2003. CORE: UFS_USB V2.8 (c) SarasSoft 2007. SERN: -xx LIC5: True BOXK: 0 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: -xx HID: -xx, HWK: A1.04-PRO1 LIC: True Authentication stage error: Error: Server returned unrecognized reply! Are you using latest client software version? | |
The Following User Says Thank You to alanic For This Useful Post: |
![]() | #7 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2009 Location: Kolkata, India Age: 47
Member: 1164699 Status: Offline Thanks Meter: 56 | my box update successfully but not run hwk I completed all procedure step by step successfully by ufs panel 2.3.0.3. 1. Scan box, 2. Chek box, 3. update box, 4. Chek box, 5. software tab, 6. chek server, 7. Install. But still now I am facing this problem. If I start dctx_BB5 then I get info: none authorised copy of software detected, please use original instalation tools, version 2.3.0.3 or higher. I also applied Salif Gsm Installer set up, no result. help.... |
The Following User Says Thank You to cdas For This Useful Post: |
![]() | #8 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Mar 2011 Location: ..::PAKISTAN::.. Age: 23
Member: 1530955 Status: Offline Sonork: 100.1627356 Thanks Meter: 213 | contac ::my yahoo id [email protected] |
![]() | #9 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2008 Location: mumbai Age: 38
Member: 709604 Status: Offline Thanks Meter: 173 | do not try everyday try it update after 8 day i already tried & success also so be free with them |
The Following User Says Thank You to krishna.cell For This Useful Post: |
![]() | #11 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2007 Location: Asia Mobiles Repairing (Swabi)
Member: 435412 Status: Offline Sonork: 100.1608142 Thanks Meter: 234 | Quote:
![]() | #12 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2010 Location: Dadu Sindh Pakistan Age: 31
Member: 1322713 Status: Offline Sonork: 100.1663786 Thanks Meter: 243 | Same Problem With my box I Hv reinstall Support suite many time but after one day i m facing same error none authorised copy of software detected, please use original instalation tools, version 2.3.0.3 or higher... i also reinstall PC windows but not sucsses plz help me........ |
![]() | #13 (permalink) |
Junior Member Join Date: Oct 2008
Member: 885076 Status: Offline Thanks Meter: 2 | same too with my ufshwk(im using old box)... i install at my 1st pc it appear "none authorised copy of software detected"..when i open dctxbb5 and other... i try to reinstall from support again and it get normally...but if i close the program and open again it back appear "none authorised copy of software detected" again. and with my 2nd pc after install it i have "none authorised copy of software detected" while i reinstall many times it wont get normally.....please fix it... |
