07-30-2013, 13:51 | #1 (permalink) |
No Life Poster Join Date: Jul 2011 Location: Lahore
Member: 1611524 Status: Offline Sonork: 100.1637126 Thanks Meter: 385 | UFS Update 2.3.0 1 : Scan Box 2 : Check Box 3 : then go to Software and check server 4 : Install http://img542.imageshack.us/img542/5706/tcm9.jpg UFS_PANEL_OK - Download - 4shared Br GSM.SOLVE |
The Following 48 Users Say Thank You to GSM.solve For This Useful Post: |
07-30-2013, 18:36 | #4 (permalink) |
Freak Poster Join Date: Jan 2007 Location: ആലുവ
Member: 439555 Status: Offline Sonork: 100.1603756 Thanks Meter: 139 | shani.. i think new update,will work only with new box. cant use new features with old box. have you tested. pls post whats news in new software with old BOX ? |
The Following 4 Users Say Thank You to RATHISH.TR_ALUVA For This Useful Post: |
07-30-2013, 18:46 | #5 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Root tunnel Age: 36
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | Yes it is working with old box.. Here i have x2-02 rm 694 checking .. Major changes are in nokia and samsung.. Nokia=New models are added.... SAMs=Android and new models are added for flahing unlock and imei option.... |
The Following 2 Users Say Thank You to zishhaider For This Useful Post: |
07-30-2013, 18:56 | #6 (permalink) |
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | DCTxBB5 V 2.3.0.0 ----------- 1. BB5 RAPU Based Products USB Flashing / UI support added: RM-754 (801T) 2. DCT4 INFINEON Based Products USB Flashing / UI support added: RM-694,RM-761,RM-799,RM-800 (X2-02,200,201,201.1) SAms V 2.3.0.0 ------ SWIFT T456-FIDO,T456-ROGERS added (UNL,SECT,IM,FL) SWIFT-AEROFONE [Patch MSL] fixed for DUOS Products. E1086W,E1153i,E1182-CHN,E1195L,E1200,E1200M,E1200M-CHN, E1200T,E1202,E1205,E1205L,E1205M-CHN,E1205T,E1207,E1207T-IND, E1207-MEA,E1220T,E1230T,E1232B,E1232D added (PUNL,PIM,FL) C3520,C3780,C3782,E2250,E2252 added (UNL,SECT,IM,FL) E2220,E2222L (UNL,SECT,IM) SWIFT-3G C3630,C5190,C5530,E3217B,E3217L,S5270K,S5270L,S568 0 added (UNL,SECT,FL) C5010,E3210,E3213,S5610 Direct Unlock Fixed. IMEI Repair Added for Almost All Models: C3630,E2310,E2313,S3710,S5270,S5610,.. INFINEON C3310,C3310R,C3312,C3312R,C3313K,C3330,C3332,C3350 ,C3350M, E2230L,E2350B,E2600,E2600M,S3800,S3802,S3802W,S522 0,S5220R, S5222,S5222R,S5229,S5292,S5296 added (CUNL,PUNL,PIM,FL,UFL) E1151 Missing boot fixed. E1151 IMEI Rebuild and Direct Unlock added (AT Mode) Note: Need make Boot Mode Info before use of AT Mode. QUALCOMM M210S,T356 Added. BROADCOM S5380B,S5380D,S5380F,S5380G,S5780D,S7250,S7250D added (UFL) SeDBx v2.0.9.0 -------- 1. Updated Drivers Support. v2.0.8.0 -------- DB2010 1. Added Support for: 36Brown, 49Brown DB2012 1. Added Support for: 50Brown, 51Brown, 51Red, 53Red. 2. Added CID Upgrade. DB2020 1. Added Support for: 49Brown. 2. Loaders Updated. PNX5230 1. Added Support for: 49Brown, 52Brown. 2. Loaders Updated. LG_GSM v 2.3.0.0 ------- 1. Infineon Egold Boot Fixed (was broken in v 2.2.0.3) 2. Infineon E500,KM553,KM555,KM555e,KM555g,KM555R added (FL,CUL) 3. Infineon GT370,GU230GO,S367 added (FL,CUL,DUL,IM) 4. Infineon T370,T375,T385,T385b,T395,T500GO,T505GO,T565, T565b,T575 added (FL,DUL) 5. MTK: A290 added (FL,3xIM) 6. MTK: USB Support for UI Functions (Select COM on Phone) 7. WiFi MAC Address Write Added for Infineon and MTK platforms. |
The Following 10 Users Say Thank You to zishhaider For This Useful Post: |
07-30-2013, 19:24 | #8 (permalink) | |
Member: 1611524 Status: Offline Sonork: 100.1637126 Thanks Meter: 385 | Quote:
Br GSM.SOLVE | |
The Following User Says Thank You to GSM.solve For This Useful Post: |
07-30-2013, 21:20 | #9 (permalink) |
Insane Poster Join Date: Jan 2011 Location: antananarivo/madagascar
Member: 1500825 Status: Offline Thanks Meter: 21 | dont work for me here is log BOOT: UFxBoot V2.2 (c) SarasSoft 2003. CORE: UFS_USB V2.8 (c) SarasSoft 2007. SERN: 76239 LIC5: True BOXK: 0 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 76239 HID: , HWK: HWK: NOT AUTHORISED, Update Box Bad IX: ABCD Failed: -6 |
The Following 4 Users Say Thank You to iiandry For This Useful Post: |
07-31-2013, 08:02 | #12 (permalink) | |
The Following 3 Users Say Thank You to GSM.solve For This Useful Post: |
