Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > UFS2 + UFS3-Tornadoflasher
Old 03-24-2010, 13:47   #1 (permalink)
andyvikas's Avatar
Member: 449069
How to Repair UFS Box!!
I Have Tried Writing Eprom Provided in These Threads
Mprog My box Collection!!!
But Even Though The Eprom Gets Written, The Power LED of my UFS box doesn't Glow!!!
The Following error i am Getting in Using it with MX Key..
Using device: UFS3 SarasSoft
Unable to boot UFS !
Error opening !
Last error: The handle is invalid (code: 6)
UFS3 SarasSoft disconnected.
When i am using it with UFS The following Error pops up..
can't boot UFS
Unexpected Exception: BOX_AUTH_ERROR:-1
How to get back this box in working condition..
The Following User Says Thank You to andyvikas For This Useful Post:
Old 03-24-2010, 14:00   #2 (permalink)
Dave.W's Avatar
Member: 7653
The problem appears to not be with FTDI or eeprom.
Maybe a problem with the ATmega processor software (doubtful..)
First check the hardware, see what levels you are finding inside there (does the atmega chip recieve VCC? You can find pinout of these processors real easy in google).
Br,
The Following User Says Thank You to Dave.W For This Useful Post:
Old 03-25-2010, 08:01   #3 (permalink)
andyvikas's Avatar
Member: 449069
Can I Have Circuit Diagram(Schematics) of UFS??
Thanks
Old 03-25-2010, 09:11   #4 (permalink)
Dave.W's Avatar
Member: 7653
Really it's not needed, UFS hardware is so simple..
Old 03-26-2010, 06:54   #5 (permalink)
[Shadab_M]'s Avatar
Member: 238812
Sonork: 100.1602669
Thanks
Check Power Regulator IC. Many times it is dead so not supplying power.
Br,
Shadab Ahmad
The Following User Says Thank You to [Shadab_M] For This Useful Post:
Old 03-26-2010, 07:17   #6 (permalink)
rana_jee's Avatar
Member: 290794
ATMEGA ic problem just change it and 100%%% ok
The Following User Says Thank You to rana_jee For This Useful Post:
Old 03-28-2010, 07:07   #7 (permalink)
andyvikas's Avatar
Member: 449069
Br,
Shadab Ahmad
Thanks a lot sir for your reply..
Can You Exactly show me where it is located on Board??
I Don't have the schematics, If you have it can you please share it??
Thanks for your time..
Regards
Old 03-30-2010, 05:46   #8 (permalink)
Member: 1015645
Thanks
here is my ufs box not work good when i conect with pc not show foundhardware but show alredy instal plz help where is fault urgaint plz show in pictur which parts i have change......................
The Following User Says Thank You to zeedan For This Useful Post:
Old 03-30-2010, 06:10   #9 (permalink)
RAVI_SINGH's Avatar
Member: 1178981
Sonork: 100.1596342
hello bro ,
this is software problem , plz dont open the box n hardware on it . use this software with following steps .
1 . Connect
2 . Update Firmware
3 . Exit Client
Download Link : RapidShare: 1-CLICK Web hosting - Easy Filehosting
After this process update your ufs box with saras support and then solve your problem .
The Following 4 Users Say Thank You to RAVI_SINGH For This Useful Post:
Old 03-30-2010, 11:49   #10 (permalink)
Member: 616091
any HOT area on PCB ..??
check voltage on its. generaly on V3, D7.
The Following User Says Thank You to cxacxa For This Useful Post:
Old 03-30-2010, 11:51   #11 (permalink)
GSMHEART's Avatar
Member: 727518
Sonork: 100:1588024
The Following User Says Thank You to GSMHEART For This Useful Post:
Old 03-30-2010, 13:06   #12 (permalink)
Dave.W's Avatar
Member: 7653
Really I would be surprised if the AVR was physically damaged, these chips are used a lot world wide.
Slightly more likely would be software problems, but again it's not a big posibility.
How did you flash the new ATMEGA? Can you try just a software update on the old unit?
Old 04-01-2010, 13:58   #13 (permalink)
andyvikas's Avatar
Member: 449069
Sir, Can we have a Schematic of UFS to Check???
Old 04-01-2010, 14:59   #14 (permalink)
Dave.W's Avatar
Member: 7653
Man, there is no schematic.
Inside the box is an atmega 128 processor, some voltage regulator, ftdi chip and a few passives. It really is not a difficult thing to trace.
Open the box and look inside, if you do not recognise some chips, just put the number from there into google and find the data sheet.
If you spend time working with mobile phone repair then this should be a simple task
Br,
The Following 2 Users Say Thank You to Dave.W For This Useful Post:
Old 04-01-2010, 15:54   #15 (permalink)
[Shadab_M]'s Avatar
Member: 238812
Sonork: 100.1602669
Arrow
Regards
Bro!
Look into this picture. Red marked component is Voltage regulator.
It may be on different place or on different side depending of Board manufacturer.
Br,
Shadab Ahmad
The Following 5 Users Say Thank You to [Shadab_M] For This Useful Post:
how to convert ufs box to nspro box??? Mehvishal GSM Programming & Reverse Engineering 29 05-05-2010 20:45
how to convert ufs box to nspro box??? possible? Mehvishal NSPRO 6 02-03-2010 17:05
R61 resistor value needed to repair ufs box shaak28 HWK 0 12-30-2008 03:14
Page generated in 0.55276 seconds with 12 queries
