10-08-2004, 20:18 | #4 (permalink) | |
Registered User Join Date: Aug 2004 Location: Hall Road Lhr Age: 43
Member: 76284 Status: Offline Sonork: 1001625595 Thanks Meter: 24 | Quote:
come on now tell all members , u did it in ur dream | |
10-08-2004, 20:32 | #5 (permalink) |
Guest
Posts: n/a
Member: | This feature is introduced long time ago, by other team. In fact, it's uselles, because phone has to be in working state (must be able to enter local mode) to make backup. It's obvious, you don't have to replace flash chip if phone can enter local mode, and, if phone is dead, you can not make backup. So, this is pretty uselles trick. |
10-09-2004, 04:59 | #6 (permalink) |
No Life Poster Join Date: Jul 2004 Age: 42
Member: 72851 Status: Offline Thanks Meter: 28 | But with added this feature will help repair mobile..Change flash chip without touching the UEM..Save Time And Cost @legija Although is pretty uselles trick. Can you explain how to do it??? Best Regard Gsm-W |
10-11-2004, 10:43 | #10 (permalink) |
Member: 72851 Status: Offline Thanks Meter: 28 | I use the Write UEM than i got this IMEI: xxxxxxxx-xx-xxxxxx-x, ASIC: 2 RPL File Info: IMEI: xxxxxxxxxxxxxxx CHCK: 5555 Warning: No DATA2 Record IMEI: ? PROD: ? 1st Boot Ok, DCT4, UPP: 0120 Fl0: 0x01000000-0x017FFFFF,00898874,Int 28F640W18-T Algorithm: u_intel.fia UEM Writing Done, Time: 00:04 Warning: No SIM_PROG_DATA in File Any solution?? Best Regard Gsm-W |
11-02-2004, 07:03 | #14 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | i know one member of this forum know the way "AKSHAY".... @akshay can you tell this forum pleaseeeeeeeeee...i know you have a way to repair imei without toching uem...... |
CERT packup how to write back to phone? | mssn | HWK | 4 | 07-28-2009 14:55 |
TELSDA26 N95 8GB IMEI write OK but still the same IMEI on the phone!! | KUBAT1 | Infinity-Box | 8 | 03-04-2008 19:33 |
How to write a pm back to the phone???? | smartfone | UFS2 + UFS3-Tornadoflasher | 2 | 12-20-2006 19:10 |
when UFS can write eeprom samsung | NuengEve | UFS2 + UFS3-Tornadoflasher | 1 | 01-07-2005 18:45 |
