02-04-2005, 16:50 | #1 (permalink) |
Junior Member Join Date: Jan 2005 Age: 38
Member: 108479 Status: Offline Thanks Meter: 6 | Nokia 6260 Camera Blocked How it can be resolved? Thz Andrea |
04-15-2006, 10:19 | #2 (permalink) |
Junior Member Join Date: Sep 2005
Member: 177995 Status: Offline Thanks Meter: 0 | 6260 camera inverted i got a nokia 6260 with ribbon problem i have changed the ribbon and it already functioning except for the camera . when you take own picture in which the lcd facing you the picture on lcd is inverted the only possible to view in normal is when you twist it the camera is at the back and the lcd is at the front of you. is it possible that the damage is in camera switch located biside the coiled ribbon? pls help...... |
Nokia 6260 lights/camera problem | IVAN__V | Nokia Hardware & Hardware Repair | 4 | 05-11-2007 16:46 |
Nokia 6260 camera flat (or equivalent) | invision | Nokia Hardware & Hardware Repair | 0 | 11-14-2006 02:01 |
Nokia 6260 After flash the camera doesn't work | nereida | WD2 & APE (Symbian Phones) | 0 | 10-11-2005 17:01 |
Nokia 6260 camera fault after flashing. | felix | WD2 & APE (Symbian Phones) | 5 | 09-24-2005 01:36 |
480x360 Camera Resolution on Nokia 6260... | goth.kitten | WD2 & APE (Symbian Phones) | 4 | 01-10-2005 09:16 |
