Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > UFS2 + UFS3-Tornadoflasher
Old 08-05-2013, 05:20   #1 (permalink)
Yashbanswara's Avatar
Member: 1147254
Sonork: 100.1620677
Thanks Meter: 639
Please Reinstall HWK Support Suite In 2.3.0.0
Please Sir Help Me Anyone
The Following 10 Users Say Thank You to Yashbanswara For This Useful Post:
Old 08-05-2013, 06:23   #2 (permalink)
Member: 1186632
Thanks Meter: 11
1. Uninstall ALL previous versions, you MUST uninstall HWK Suite BEFORE trying to uninstall HWK Support Suite Setup.
2. Install UFSx Support Suite Setup
3. Connect your UFSx+HWK before running the UFSx Control Panel
4. Run UFSx Control Panel
5. Select the "Hardware" Tab
6. If you only have one UFSx connected it will be selected, if more than one, select the check box next to the required UFSx. You can click "Scan Boxes" to refresh the list if you have connected further boxes since opening the Control Panel
7. Click "Check Box"
8. Click "Update Box"
9. Click "Check Box"
10. Select the "Software" Tab
11. Amend "Application Install Path" and/or Nokia Install Path, if required.
12. Click "Check Server"
13. Click "Install"
14. If you have more than 1 UFSx+HWK run steps 5-13 for each UFSx+HWK (NOTE: You must install something at step 13)
You need to uninstall old HWK Setup Suite and HWK Support Suite and use the new UFSx Support Suite.
The Following 11 Users Say Thank You to deepak gupta For This Useful Post:
Old 08-05-2013, 22:05   #3 (permalink)
Member: 171888
Thanks Meter: 16
hwk update faild-6 help please odia
The Following 2 Users Say Thank You to MAHSUN For This Useful Post:
Old 08-05-2013, 23:01   #4 (permalink)
@matrix@'s Avatar
Member: 362515
Sonork: 100.1590585
Thanks Meter: 160
Bro; install this latest suite https://hotfile.com/dl/237828814/80f...00.00.exe.html
{it's 02.03.00.01. not 02.03.00.00.}
it will help you. { pls search well before u post}
The Following 7 Users Say Thank You to @matrix@ For This Useful Post:
Old 08-05-2013, 23:05   #5 (permalink)
@matrix@'s Avatar
Member: 362515
Sonork: 100.1590585
Thanks Meter: 160
install usfx support suite setup 02.03.00.01.
The Following 5 Users Say Thank You to @matrix@ For This Useful Post:
Old 08-05-2013, 23:07   #6 (permalink)
Member: 171888
Thanks Meter: 16
yes problem hwk box not
The Following User Says Thank You to MAHSUN For This Useful Post:
Old 08-06-2013, 14:59   #7 (permalink)
bpcentergtk's Avatar
Member: 311436
Thanks Meter: 38
same here please reinstall hwk support sutie
Old 08-06-2013, 15:30   #8 (permalink)
Member: 1114945
Thanks Meter: 14
antivirus fuli off okkkkkkkkkkkkkkkkkkkkkkk 1000% tested
The Following 3 Users Say Thank You to ashokshah For This Useful Post:
Old 08-07-2013, 06:03   #9 (permalink)
jakkarzoya_2511's Avatar
Member: 613242
Sonork: 100.1626311
Thanks Meter: 645
Arrow hmm
just reinstall old hwk support suite
this ver >> HWK_Support_Suite_Setup_v02.02.000 1000% solve
b / r
jakkar
The Following 3 Users Say Thank You to jakkarzoya_2511 For This Useful Post:
Old 08-09-2013, 09:21   #10 (permalink)
Member: 1181277
Thanks Meter: 15
i have also same problem.
help me.
The Following User Says Thank You to myzoneramu For This Useful Post:
Old 08-09-2013, 09:49   #11 (permalink)
Major Boy's Avatar
Member: 1987269
Thanks Meter: 190
help me.
Uninstall your old version
download latest version
disable antivirus
update box
install this software
your problem solve
hwk_support_suite_setup_v02.03.000 - Download - 4shared - boy 9440
The Following 10 Users Say Thank You to Major Boy For This Useful Post:
Old 08-12-2013, 02:40   #12 (permalink)
Member: 1599104
Thanks Meter: 6
install old ufs support suite v2.2.0.0 100000% tested
The Following 2 Users Say Thank You to anil21589 For This Useful Post:
Old 08-12-2013, 10:22   #13 (permalink)
Member: 1382013
Thanks Meter: 3
bro......can u find any solution ???
The Following User Says Thank You to meet_03 For This Useful Post:
Old 08-12-2013, 10:27   #14 (permalink)
Member: 1382013
Thanks Meter: 3
bro..... can u find any solution for this....i have same problem
Old 08-12-2013, 10:52   #15 (permalink)
Major Boy's Avatar
Member: 1987269
Thanks Meter: 190
Restart system & try this problem solve.
Regards
ccsetup309 - Download - 4shared - boy 9440
The Following 2 Users Say Thank You to Major Boy For This Useful Post:
Page generated in 0.20697 seconds with 8 queries
