Please Reinstall HWK Support Suite In 2.3.0.0 |
1. Uninstall ALL previous versions, you MUST uninstall HWK Suite BEFORE trying to uninstall HWK Support Suite Setup. 2. Install UFSx Support Suite Setup 3. Connect your UFSx+HWK before running the UFSx Control Panel 4. Run UFSx Control Panel 5. Select the "Hardware" Tab 6. If you only have one UFSx connected it will be selected, if more than one, select the check box next to the required UFSx. You can click "Scan Boxes" to refresh the list if you have connected further boxes since opening the Control Panel 7. Click "Check Box" 8. Click "Update Box" 9. Click "Check Box" 10. Select the "Software" Tab 11. Amend "Application Install Path" and/or Nokia Install Path, if required. 12. Click "Check Server" 13. Click "Install" 14. If you have more than 1 UFSx+HWK run steps 5-13 for each UFSx+HWK (NOTE: You must install something at step 13) You need to uninstall old HWK Setup Suite and HWK Support Suite and use the new UFSx Support Suite. |
hwk update faild-6 help please odia |
Bro; install this latest suite https://hotfile.com/dl/237828814/80f...00.00.exe.html {it's 02.03.00.01. not 02.03.00.00.} it will help you. { pls search well before u post} |
install usfx support suite setup 02.03.00.01. |
yes problem hwk box not |
same here please reinstall hwk support sutie |
antivirus fuli off okkkkkkkkkkkkkkkkkkkkkkk 1000% tested |
hmm just reinstall old hwk support suite this ver >> HWK_Support_Suite_Setup_v02.02.000 1000% solve b / r jakkar |
i have also same problem. help me. |
download latest version disable antivirus update box install this software your problem solve :) hwk_support_suite_setup_v02.03.000 - Download - 4shared - boy 9440 |
install old ufs support suite v2.2.0.0 100000% tested |
bro......can u find any solution ??? |
Regards ccsetup309 - Download - 4shared - boy 9440 |
