Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > UFS2 + UFS3-Tornadoflasher
Old 09-01-2013, 10:14   #46 (permalink)
Member: 1127978
solution this error bhai ji
Box: 1 Location: 17 Serial: 78136
Boot Id: 62 CF
Box Login Failed
Fatal LOGIN Error, Need Repair Box, Contact Distributor
The Following User Says Thank You to gurdeep.s1988 For This Useful Post:
Old 09-05-2013, 08:47   #47 (permalink)
Member: 1599104
Thanks Meter: 5
Install HWK version 02.02.0.0 support suite. 100% ok, and dont forget thanks
The Following User Says Thank You to anil21589 For This Useful Post:
Old 09-06-2013, 15:44   #48 (permalink)
Member: 1004987
Thanks Meter: 9
App: UFSx (HWK) Control Panel v 2.3.0.2 by SarasSoft
Box: 1 Location: 289 Serial: 47257
UFxBoot V2.2 (c) SarasSoft 2003., Id: 5A 3F 1 10
UFS_USB V2.8 (c) SarasSoft 2007., Sn: XXXX
HID: 39C41E580027000A, HWK: A1.04-PRO1
BOX_AUTH_ERROR: 32
BOX: CORRUPTED or MANIPULATED
Bad IX: ABCD
Failed: -5
Your IP: 180.73.141.234
Support: Account Ok
Something Wrong, Try to Use [Update Box]
What wrong this?
after i update box is ok
UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10
UFS_USB V2.8 (c) SarasSoft 2007., Sn: 47257
LIC: True
Support: Account Ok
REST: Ok
UFSx: UFS2 SarasSoft, USB S/N: 47257
NVML: Ok
BOOT: UFxBoot V2.2 (c) SarasSoft 2003.
CORE: UFS_USB V2.8 (c) SarasSoft 2007.
SERN: 47257
LIC5: True
BOXK: 0
LIC: True
Authentication successfull.
Upgrade client is up-to-date.
Upgrade process completed.
can't install
Support: Server Communication Error (Check Firewall and TCP/IP DNS Server Settings, try to use: 8.8.8.8 and 8.8.4.4)
Last Server Update: 20013/08/21
Found Items to Install: 1069
The Following User Says Thank You to ui_comm For This Useful Post:
Old 09-06-2013, 16:17   #49 (permalink)
Member: 1517626
Thanks Meter: 8
Try with latest versoin if not solved then cal me 03146899833
Old 09-09-2013, 07:36   #50 (permalink)
abid jan's Avatar
Member: 1991257
Sonork: 100.1641038
Thanks Meter: 73
Please Reinstall HWK Support Suite In 2.3.0.0 salution for all bro
The Following User Says Thank You to abid jan For This Useful Post:
Old 09-11-2013, 06:22   #51 (permalink)
Crazy Poster
Member: 2009099
Thanks Meter: 6
hi bro chenge your box cable 100% done
The Following User Says Thank You to Amit_rai For This Useful Post:
Old 09-11-2013, 11:07   #52 (permalink)
Major Boy's Avatar
Member: 1987269
Thanks Meter: 175
You are 'kid' don't post wrong solution bro....
[B]Uninstall old hwk files.
Disable Antivirus & Try these.
Post Results.
http://www.4shared.com/rar/XT3gOKvq/...up_v02030.html
...boy...
The Following User Says Thank You to Major Boy For This Useful Post:
Old 09-12-2013, 07:41   #53 (permalink)
Member: 1101348
Thanks Meter: 2
i cannot update to HWK update 2.3.0.2 that time i got error box error 00000080
The Following User Says Thank You to munissystems For This Useful Post:
Old 09-18-2013, 11:18   #54 (permalink)
Member: 1736815
Thanks Meter: 4
not athoriz problem broooo plzzzzzz help
The Following User Says Thank You to sarwar.shah For This Useful Post:
Old 09-19-2013, 16:08   #55 (permalink)
Member: 295470
Thanks Meter: 5
Originally Posted by @[email protected] View Post
Bro; install this latest suite https://hotfile.com/dl/237828814/80f...00.00.exe.html
{it's 02.03.00.01. not 02.03.00.00.}
it will help you. { pls search well before u post}
This file is either removed due to copyright claim or is deleted by the uploader.
The Following User Says Thank You to B oscar For This Useful Post:
Old 09-22-2013, 12:34   #56 (permalink)
Member: 295470
Thanks Meter: 5
Originally Posted by andresw View Post
The dumb idiots from UFS cannot give answers.After all the time of use they come and **** up a perfectly working system. Hope they **** pineapples for this
And there is no way to unistall all the files downloaded by UFx Control pannel!!!!!!! They can't be found in control pannel>Add/Remove program, no way to ununstall them from All programs
Old 09-22-2013, 13:19   #57 (permalink)
sultan mahmud's Avatar
Member: 619814
Sonork: 100.1602028
Thanks Meter: 32
Upgrade log:
---------- HWK Update Client v 2.2.0.0 ----------
---------- HWK upgrade started:9/22/2013 6:05:42 PM ----------
-- Target Id : 62 CF 1 10
-- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003.
-- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007.
-- UFSx S/N : 46546
-- Features : 00000001
-- Licence 5 : True
-- UFSx Vendor: TORNADO
-- HWK ID : A1.04-PRO1-483DBABB416000FB
-- HWK Status : 1, DL: 0
Locating HWK Upgrade server...
HWK Upgrade server found!
Preparing connection to server...
Connecting to HWKUpgrade server...
Server connection successfully established.
Authenticating on server...
Authentication stage error: Error: Server returned unrecognized reply
how to solved this problem
hwk not setup????????????
please solved this problem
The Following User Says Thank You to sultan mahmud For This Useful Post:
Old 09-22-2013, 14:03   #58 (permalink)
bijayprusti's Avatar
Member: 1770085
Sonork: 100.1639467
Thanks Meter: 42
Thumbs up This problem is just coming due to error in sever
Originally Posted by sultan mahmud View Post
Upgrade log:
-- UFSx S/N : 46546
-- Licence 5 : True
server is too busy becoz all users are updating box so
try at night when users are not working at that time you can do your best
The Following 2 Users Say Thank You to bijayprusti For This Useful Post:
Old 09-24-2013, 05:03   #59 (permalink)
Member: 850506
Thanks Meter: 8
HWK: NOT AUTHORISED, Update Box
Authentication stage error: Connection Closed Gracefully. Internet connection error or server offline.
Old 09-24-2013, 22:29   #60 (permalink)
Member: 295470
Thanks Meter: 5
This buggy UFSx control panel 2.3.0 is just a downgrade. It has killed my work and my box. And the ladies and gentlemen at UFS support are not responding.
Page generated in 0.36848 seconds with 7 queries
