Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > UFS2 + UFS3-Tornadoflasher
Old 09-25-2013, 13:37   #61 (permalink)
Abul Basher's Avatar
Member: 1675107
Sonork: n/a
Thanks Meter: 106
JUST OREG support sutie http://www.ufshwk.com/hwk-suite-down...allation-setup Download & Update Box & Instal ALL file server is problem try to 48 hour leter
The Following 3 Users Say Thank You to Abul Basher For This Useful Post:
Old 09-25-2013, 18:45   #62 (permalink)
Member: 1540475
Sonork: Alaminakas
100% this problem solve.
Old 09-26-2013, 11:18   #63 (permalink)
Member: 295470
Thanks Meter: 5
Originally Posted by Abul Basher View Post
JUST OREG support sutie HWK Suite Setup Download & Update Box & Instal ALL file server is problem try to 48 hour leter
But why did they shut down the perfectly working old version before the new one is ready?
Old 09-28-2013, 12:43   #64 (permalink)
SAJONDUTTA's Avatar
Member: 926902
Sonork: 100.1655575
Thanks Meter: 305
install usfx support suite setup 02.03.00.02. all ok i tested
Old 09-28-2013, 13:55   #65 (permalink)
Member: 1681706
Sonork: 1681706
Thanks Meter: 5
LIC: True
HWK: NOT AUTHORISED, Update Box
Bad IX: ABCD
Failed: 2
Support: Server Communication Error (Check Firewall and TCP/IP DNS Server Settings, try to use: 8.8.8.8 and 8.8.4.4)
plz help
Old 09-28-2013, 21:20   #66 (permalink)
Member: 2023399
Red face
Bad environment -1 (bad driver) current usb not authorized SYS: 2.6.0 DLL 3.1.1.19 please install usb driver..I reinstalled all the drivers but nothing happen.. and when I press ok (access violation at address 00000 read 00000) appears..help please
Old 09-29-2013, 00:23   #67 (permalink)
Member: 295470
Thanks Meter: 5
This HWK Suite Setup worked for me.
Uninstall all UFSx staff (drivers and support suite) from control panel and restart your pc. install UFSx_Support_Suite_Setup_v02.03.00.02. When the setup asks to install new driver ignore it and complete the installation. Now go to C:\Program Files\SarasSoft\UFS\UFS_USB_Driver and manually install the box driver (INSTALL_32_XP_Vista_W7). Connect your box and start UFSx control panel. The box should be detected and selected. Click Check Box. At this level if the computer hangs, (it is what happened to my Windows XP) disconnect the box and reconnect. Click Update Box. Follow the rest of the instructions from HWK Suite Setup. Make sure you have an active internet connection.
The installation is challenging.
Old 09-29-2013, 11:21   #68 (permalink)
Member: 2023399
Thanks got it working now after I ignored the new driver installation. But the problem now is when I restart the pc it goes back with the same problem. And I tried to update the box but it says Not authorized server reported error..no more upgrade logs contact reseller
Old 09-29-2013, 21:03   #69 (permalink)
Member: 295470
Thanks Meter: 5
So, you haven't been able to download the rest of installation files from the server?
Old 10-01-2013, 11:44   #70 (permalink)
shahidjanu's Avatar
Member: 1706213
Thanks Meter: 153
hwk
Old 10-01-2013, 12:00   #71 (permalink)
shahidjanu's Avatar
Member: 1706213
Thanks Meter: 153
help me pzzzzzzzzzzzzzzzzzzz
Old 10-03-2013, 02:20   #72 (permalink)
-=noke23=-'s Avatar
Member: 1626732
Sonork: gsmhosting
Thanks Meter: 17
Originally Posted by sultan mahmud View Post
upgrade log:
---------- hwk update client v 2.2.0.0 ----------
---------- hwk upgrade started:9/22/2013 6:05:42 pm ----------
-- target id : 62 cf 1 10
-- ufsx boot : Ufxboot v2.2 (c) sarassoft 2003.
-- ufsx firmw.: Ufs_usb v2.8 (c) sarassoft 2007.
-- ufsx s/n : 46546
-- features : 00000001
-- licence 5 : True
-- ufsx vendor: Tornado
-- hwk id : A1.04-pro1-483dbabb416000fb
-- hwk status : 1, dl: 0
locating hwk upgrade server...
Hwk upgrade server found!
Preparing connection to server...
Connecting to hwkupgrade server...
Server connection successfully established.
Authenticating on server...
Authentication stage error: Error: Server returned unrecognized reply
how to solved this problem
hwk not setup????????????
Please solved this problem
many problem of hwk are same like this?pls help all suporter from this product thans advance
Old 10-03-2013, 09:36   #73 (permalink)
shahidjanu's Avatar
Member: 1706213
Thanks Meter: 153
hwk team plz help
Old 10-03-2013, 09:42   #74 (permalink)
shahidjanu's Avatar
Member: 1706213
Thanks Meter: 153
is se acha to old version tha jo asani se update to ho rha tha 3din se support error kiya problem hai kuch samjh nhi arha
Old 10-10-2013, 06:16   #75 (permalink)
Member: 1873757
Thanks Meter: 4
tanks to gsm forum be case its usefull and uodete us tanks alot
The Following User Says Thank You to munibkhan For This Useful Post:
Page generated in 0.75361 seconds with 7 queries
