Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > UFS2 + UFS3-Tornadoflasher
Old 06-09-2005, 15:44   #1 (permalink)
Member: 149130
is it possible to???
hi i have tried updating software on anokia 3220 and now lost all themes etc,i have read that i need to reflash a cnt pack because this is where that stuff is saved.
i have an identical mobile same software version bought at the same time is it possible to record the cnt part of that mobile and send it to the empty 3220???
many thanks rob
Old 06-09-2005, 16:12   #2 (permalink)
amitks_in's Avatar
Member: 111665
U cant read this file ! check here ! In ur Rh-37 folder search this file rh37__03.30.image_a this is cnt file load it and u will get all ur media back !
Old 06-09-2005, 20:23   #3 (permalink)
Member: 149130
thankyou ever so nuch very nice to get a reply,all files in the rh37 directory i have found to be confusing,as it oesnt really say anywhere what they all are!!can i just flash the cnt part on its own or do i have to flash the m,cu part aswell?if so would you be so kind as to type the name of that file also,as you have made the cnt bit very easy for me now!!many thanks my friend
Old 06-09-2005, 20:31   #4 (permalink)
Member: 149130
also in the rh37 folder does any one know what these files are for?
rh37__04.54a 54a file
rh37__04.54b 54b file
rh37__04.54c 54c file
etc!
Old 06-09-2005, 20:44   #5 (permalink)
Member: 149130
i havent got 3.30 only this one rh37__04.54.image_a
Old 06-10-2005, 06:05   #6 (permalink)
amitks_in's Avatar
Member: 111665
etc!
These are PPM file ( Language files ) If u select a as ppm then u have to select CNT (content file ) also with a !
Old 06-10-2005, 06:08   #7 (permalink)
amitks_in's Avatar
Member: 111665
Ok this is your content file ! Now select rh37__04.54a as a ppm and rh37__04.540 as MCU !
Old 06-10-2005, 06:09   #8 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
no need to search which files to flash....
just download karwossuite, select ini_bd tab, 3220 model, variant for you rcountry
and then "Build ini". That's all.
Old 06-10-2005, 07:01   #9 (permalink)
amitks_in's Avatar
Member: 111665
Good ! this will B much easy for new users ! Good Job !
Old 06-11-2005, 16:10   #10 (permalink)
Member: 149130
perfect thats all i can say everything backl to normal knowledege is power and you all have got plenty of that!!!thankyou very much
Is it possible to clone sim without having direct access to it??? BilalMehdi Sim Cloning and Scaning 2 09-15-2008 11:25
SMS Animated Indicator-Is it possible to correct it? GoLL@B x4x, x5x Flashpatching 0 11-12-2005 10:39
Is it possible to flash 8130 v 106+ , please post just if you did it already gsmnice LG 8 04-13-2005 01:17
T610 is it possible to unlock or does it have TP ? Gsmhq Twisterflasher 10 08-21-2004 16:15
Is it possible to lock phone again, as it was then I bought it? jonis2002 x1x to x45/x50 4 09-27-2002 21:17
Page generated in 0.47336 seconds with 11 queries
