Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > UFS2 + UFS3-Tornadoflasher
Old 09-13-2015, 09:11   #1561 (permalink)
Member: 1288187
Thanks Meter: 2
UFS micro + HWK, not upgrade..
the programm UFS_PANEL_2307, hang after press key check box or Update box
system is clean
i am try the change windows xp\ windows 7, - no results.
change drivers (all version old and new).
Plz help me in this problem.
on the attachment, i am delete the serial number.
AMD Athlon(tm) 64 X2 Dual Core Processor 6000+, 3013 МГц
Old 10-09-2015, 07:49   #1562 (permalink)
Member: 1994919
Sonork: 100.1670912
Thanks Meter: 120
What is solution
for this error ?
UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10
UFS_USB V2.8 (c) SarasSoft 2007., Sn: 93206
HID: 800E1FB641600033, HWK: A1.04-PRO1
LIC: True
Your IP: 182.186.167.216
Support: Account Ok
REST: Ok
UFSx: UFS3 SarasSoft, USB S/N: 93206
NVML: Ok
BOOT: UFxBoot V2.2 (c) SarasSoft 2003.
CORE: UFS_USB V2.8 (c) SarasSoft 2007.
SERN: 93206
LIC5: True
BOXK: 1
LIC: True
Authentication stage error: Server reported error: No more upgrade logs. Please contact your reseller!
Old 01-25-2016, 12:21   #1563 (permalink)
Member: 1844158
Thanks Meter: 2
App: UFSx (HWK) Control Panel v 2.3.0.7 by SarasSoft
CPU: GenuineIntel
Platform: Windows NT 6.1 (Build 7600 )
Versions: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30
C:\Program Files
C:\Program Files\Common Files
Nokia Path not Found, Set to: C:\Program Files\Nokia\Phoenix
Can't open internet URL. InternetOpenURL failed!
Last Server Update: 2015/12/31
Active Panel Version: 2.3.0.7
Ftd: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30
Box: 1 Location: 8467 Serial: 90090
UFS_USB V2.8 (c) SarasSoft 2007., Sn: 90090
HWK Preset 1 Error: 00, 0
BOX_AUTH_ERROR: 52
BOX: CORRUPTED or MANIPULATED
Bad IX: ABCD
Failed: -5
Your IP: 203.171.243.142
Support: Bad HID, Cannot Access Support
Something Wrong, Try to Use [Update Box]
BOX_AUTH_ERROR: 52
-- Reset Failed, Trying to Repair UFS ...
-- Boot: 62 CF
-- Done, use [Update Box] to authorise UFS.
UFSx: UFS3 SarasSoft, USB S/N: 90090
NVML: Ok
SERN: 90090
LIC5: False
REQ FBI Failed !
solution please.....
Old 01-29-2016, 06:03   #1564 (permalink)
Member: 2299507
Sonork: no
Old 02-04-2016, 06:40   #1565 (permalink)
Crazy Poster
Member: 519737
Thanks Meter: 3
please help....
my ufs-3 box was working fine till day before yesterday ...yesterday when It suddenly showed hwk not authorized update the box, since yesterday I am trying to update it shows following error
REST: Ok
UFSx: UFS3 SarasSoft, USB S/N: xxxxx
NVML: Ok
SERN: xxxxx
LIC5: True
BOXK: 1
UFS_USB V2.8 (c) SarasSoft 2007., Sn: xxxx
HWK Preset 2 Error: 10, -4
HID: , HWK: NOT CONNECTED 45
Fatal: Bad HWK Module
anyone out there who can help me out of this problem....thanks in advance
Old 02-04-2016, 06:54   #1566 (permalink)
Crazy Poster
Member: 519737
Thanks Meter: 3
did you find any solution?
Old 02-11-2016, 11:22   #1567 (permalink)
Member: 2271452
Sonork: no
I have same problem plz, help
Old 03-14-2016, 13:36   #1568 (permalink)
Member: 667392
help me plezzzzzzzzzzzzzzzzz
BOX_AUTH_ERROR: 52
Your IP: 197.165.129.58
-- Boot: 62 CF
SERN:
LIC5: False
REQ FBI Failed !
Old 03-14-2016, 13:57   #1569 (permalink)
Member: 667392
Box: 1 Location: 8529 Serial: xxxx
UFS_USB V2.8 (c) SarasSoft 2007., Sn: xxxxx
HID: D9979D4D012700EA, HWK: A1.04-PRO1
LIC: True
BoxStat : Ok
Support: Unknown Server Error
Update Box and try again in 8 Hours (max). If not, Contact Distributor About Support
Old 12-11-2016, 04:15   #1570 (permalink)
smkab143's Avatar
Member: 1830045
Thanks Meter: 39
pLEASE help not instal ufs3
Connection to server failed. Socket Error # 10060
Connection timed out.(A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.)
Old 12-11-2016, 04:15   #1571 (permalink)
smkab143's Avatar
Member: 1830045
Thanks Meter: 39
Old 02-09-2017, 23:58   #1572 (permalink)
Member: 2683092
Sonork: familly
hi members,are all good
Old 02-10-2017, 00:04   #1573 (permalink)
Member: 2683015
sm-b310
i need some help !
sm b310 ... flashing !!!
Old 03-08-2017, 11:45   #1574 (permalink)
Member: 1948180
Thanks Meter: 36
Unexpected exception. Cannot Access Support
The Following User Says Thank You to exploit69 For This Useful Post:
Old 12-23-2017, 15:56   #1575 (permalink)
Member: 2749644
Sonork: 100.1678692
Thanks Meter: 47
ufst server
same error for past 3 weeks ..team please work on it
G]
Post here all successfuly flashed, unlocked and repaired phones with ATF software. dr_aybyd Advance-Box 6048 02-04-2019 16:48
Post here all Nokia 1200,1208,1209 and 1650 Network problems mobilecitycbk Nokia Hardware & Hardware Repair 12 09-20-2015 04:01
Post here all UFS 3 Tornado Box Tutorilas and videos?? nofear99 Nokia Base Band 5 ( BB-5 ) 2 01-24-2015 06:12
all members can post here all moto L7.L6.V3 and more of problem and also post solutio 786sunny Motorola Hardware Repair 3 04-12-2007 17:53
Page generated in 0.35199 seconds with 11 queries
