12-14-2008, 20:21 | #1157 (permalink) |
No Life Poster Join Date: May 2006 Location: zambia
Member: 272581 Status: Offline Thanks Meter: 118 | check if your imei is ??????????????, if so u need to use ask-rpl service to repair ur imei, if this doesnt work too then ul have to change uem chip (first check if your phone powers of itself within 1 minute without simcard) |
12-14-2008, 20:30 | #1158 (permalink) |
Member: 272581 Status: Offline Thanks Meter: 118 | try removing the mainboard from the housing then put the contacts of the the rj45 cable on the mainbord of phone. If this doesn't work, check the small black component which is near the six points where u put flashing cable on the left side, make sure is not broken, try re-heating it, then try flashing...good luck and post result |
12-14-2008, 20:51 | #1162 (permalink) | |
Member: 272581 Status: Offline Thanks Meter: 118 | Quote:
12-14-2008, 20:58 | #1163 (permalink) | |
12-14-2008, 21:02 | #1164 (permalink) | |
remove mainboard from housing and conect flashng cable to mainboard (with housing removed)..post result, gud luck...also try using the flashing cable that does not require 9v battery | |
01-08-2009, 16:11 | #1168 (permalink) |
Junior Member Join Date: Oct 2008
Member: 874595 Status: Offline Thanks Meter: 0 | my ufs3 is down hi to all friends please help my ufs3 box is not functioning correctly its always fail put the phone in normal mode or test and displays : first boot error first boot error while the cable is OK and i have test it with another box also the phone is tested in other box it connects well so any one can help guys my box is down . i have attached some picture so u can check . Last edited by mmtagga; 01-08-2009 at 16:18. Reason: attach file |
01-10-2009, 14:34 | #1169 (permalink) |
Junior Member Join Date: Dec 2004 Age: 49
Member: 95664 Status: Offline Thanks Meter: 0 | lg kg275 unlock problem hi, i have a problem when unlocking lg kg275 tornado unlock phone but an error message comes and say that i must repair imei end eeprom. i dowload from support the flash but no ''.ee'' file so i flash the phone but still same problem : phone is unlock and starts properly and all seems to be ok but when you call, call is stopped in few seconds alone. any solution? |
Post here all successfuly flashed, unlocked and repaired phones with ATF software. | dr_aybyd | Advance-Box | 6048 | 02-04-2019 16:48 |
Post here all Nokia 1200,1208,1209 and 1650 Network problems | mobilecitycbk | Nokia Hardware & Hardware Repair | 12 | 09-20-2015 04:01 |
Post here all UFS 3 Tornado Box Tutorilas and videos?? | nofear99 | Nokia Base Band 5 ( BB-5 ) | 2 | 01-24-2015 06:12 |
all members can post here all moto L7.L6.V3 and more of problem and also post solutio | 786sunny | Motorola Hardware Repair | 3 | 04-12-2007 17:53 |
