Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > UFS2 + UFS3-Tornadoflasher
Old 09-20-2004, 11:45   #16 (permalink)
Member: 41491
Cool
But I was able to repair by flashing it with Neelix2... Griffin cannot repair also BT system error...
tested on 7650, 3650 and 6310i...
Originally Posted by mobileland
@xileen2k
UFS solves all problems on simbian phones and is best tool for repairing those phones.
If it can't repair BT problems than change bluetooth IC !
Best regards!
Old 09-20-2004, 11:47   #17 (permalink)
Member: 41491
But of course UFS / Twister is the still the best among all flashers around..
It's only on case to case basis on how to fix one phone...
Old 09-20-2004, 12:49   #18 (permalink)
Member: 30945
flashing 7250i not working,
reading=ok
unlock=ok
format user area not work(wrong cable???)
where is shema for cable 5210?
The Following User Says Thank You to luis035 For This Useful Post:
Old 09-20-2004, 15:25   #19 (permalink)
Member: 82866
only problem im encounter in UFS is sometimes when i connect usb cable at the back of UFS and connect BAD RESPONCE 2, and wait 30-1 hrs to get it normal again. why?
Old 09-20-2004, 15:52   #20 (permalink)
Member: 60442
When i check the phone with v1.3d i get always the error:
1st boot err: bad response ufs
1st boot err: bad ufs response 1
rebooting mobile
happened with 3310 ngage 6820 and 7250i
Old 09-20-2004, 15:52   #21 (permalink)
Member: 60442
oh and i've i use v1.3b everything is oke
Old 09-21-2004, 11:19   #22 (permalink)
e64y's Avatar
Member: 30582
Flash files browsing problem doesnt happen to me;Samung S500 cannot read,write flash,always boot failed,read mobile info,cannot enter TAT mode,samsung T100 failed to read flash;also famous Pm reading problem for symbian phone need to try many times and keep adjust F_delay at ini files then success.
Old 09-21-2004, 11:22   #23 (permalink)
Member: 77439
The program wont even start! (Dctx_ufs)
USB-driver are installed correct, but still no go. The freia-soft starts up fine.
Old 09-21-2004, 11:25   #24 (permalink)
Member: 13808
Maybe as a suggestion ADSP flashing should be implemented in new update..
bR
Old 09-21-2004, 11:27   #25 (permalink)
e64y's Avatar
Member: 30582
bR
You r right!!we need it badly.
Old 09-21-2004, 14:27   #26 (permalink)
hooi76's Avatar
Member: 7741
flashing the 8250
1st Boot Err: Bad Resp DCT3
1st Boot Err: Bad Resp UPP, 02 FF FF 72
Rebooting Mobile
Please see picture that i attached for cable schematic, i test one with diode to Vbat and THE OTHER one without diode to Vbat. But still can't flash the phone
The Following User Says Thank You to hooi76 For This Useful Post:
Old 09-22-2004, 09:09   #27 (permalink)
Member: 22040
hi big tornado problem
helo to all I have problem with me tornado ufs3 frst have serial nm 16281
but string miss after change serial nm to 65535 and work only vith old software to all if you can help with this case to send me new string code
to make funcional this flasher big thank to alll
ps me resaler its lose I cold can find hem
thanks agen
Old 09-22-2004, 12:34   #28 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
and one problem is it is unable to repair the ????????????4 imei problem as GRiffin can repair it...
and when we unlock the nokia 2280 CDMA there is no network after unlock..
please check this..
thanks
Old 09-23-2004, 16:27   #29 (permalink)
Member: 82866
i flash N-gage Contact Retailer In UFS same problem, even i erase flash file and flash it again same message given to me is there any way of flashing or technique to solve this problem is UFS????????
Old 09-23-2004, 16:43   #30 (permalink)
dejo's Avatar
Member: 28586
Sonork: 100.68088
... change bluetooth IC !
I have 6600 with damaged bluetooth IC. Can you tell me where I can buy BT IC?
Guys, lot of yours problem is simple, my problem is HW problem with box, my box go away Well, this is bad for me
Post here all successfuly flashed, unlocked and repaired phones with ATF software. dr_aybyd Advance-Box 4344 05-18-2013 09:19
Post here all UFS 3 Tornado Box Tutorilas and videos?? nofear99 Nokia Base Band 5 ( BB-5 ) 1 10-16-2010 13:47
Post here all Nokia 1200,1208,1209 and 1650 Network problems mobilecitycbk Nokia Hardware & Hardware-Repair Area 11 12-23-2009 16:23
all members can post here all moto L7.L6.V3 and more of problem and also post solutio 786sunny Motorola Hardware Repair Section 3 04-12-2007 17:53
Page generated in 1.90635 seconds with 12 queries
