Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > UFS2 + UFS3-Tornadoflasher
Old 06-07-2004, 23:00   #1 (permalink)
ViperGSM's Avatar
Member: 49634
Sonork: 100.1671023
Thanks Meter: 71
Problem with flashing 5210
I cant flash 5210 with my tornado,when i connect phone it turns on,read info Ok but reports error when try to flash.Cable is OK,it works with 8210,2100...Tia files are ok also.Can Any1 help me,is there any solution?
Old 06-07-2004, 23:32   #2 (permalink)
johnnymld's Avatar
Member: 67014
ok man just tald me what phone version is 5210 and is tornado and griffin uses same flash files (neliks)? if that is send me a mail on my mail and i sand it to you or i send you by a bus!
johnnymld@beotel,yu
Old 06-07-2004, 23:45   #3 (permalink)
ViperGSM's Avatar
Member: 49634
Sonork: 100.1671023
Thanks Meter: 71
i have all the versions till 5.40,griffin,nelix,tornado uses same flash files and tia and fia.i cant understand what are you trying to say...
Old 06-08-2004, 22:53   #4 (permalink)
Falck's Avatar
Member: 18805
Thanks Meter: 27
Cable is NOT OK, just check DCT3 corrected cable scheme from support and notice that 1N4002 diode is neccessary for 5210 models.
http://www.mobilkabler.dk/support/fo..._corrected.pdf
WBR Falck_12unlock
Old 06-09-2004, 00:35   #5 (permalink)
Akoska's Avatar
Member: 2054
Thanks Meter: 10
@Falck
for me link doesn't work...
Old 06-09-2004, 05:24   #6 (permalink)
Falck's Avatar
Member: 18805
Thanks Meter: 27
@Akoska
Try the link here, if doesn't work U can also find scheme at UFS/Tornado support sites.
http://www.mobilkabler.dk/support/fo...?f=7&i=59&t=59
WBR Falck_12unlock
Old 06-09-2004, 06:15   #7 (permalink)
newbird's Avatar
Member: 31101
5210
Use old programme.Use knok.It is 100% works
Old 06-09-2004, 15:34   #8 (permalink)
vule's Avatar
Member: 10854
Sonork: 1578988
Thanks Meter: 3
Even with corrected cable it won't work....
Vule
Old 06-10-2004, 06:23   #9 (permalink)
brka1's Avatar
Member: 4395
Thanks Meter: 159
Vule
same problem
but work with 2100????
stupid thing....
Old 06-10-2004, 09:23   #10 (permalink)
ViperGSM's Avatar
Member: 49634
Sonork: 100.1671023
Thanks Meter: 71
Support,where are you?
Old 11-17-2004, 19:34   #11 (permalink)
webmoly's Avatar
Member: 66171
Thanks Meter: 6
Hi
where can I download 5210 MCU and PPM with Persian or english language ? Its flash files are not listed in UFS support area.
can anyone gimme a link to download them or send them to [email protected] ?
hope to hear soon
have fun
moly
Old 11-17-2004, 20:04   #12 (permalink)
newbird's Avatar
Member: 31101
Use nok tools ,software which ufs are not yet born.Use NOk TOOLS
Old 11-17-2004, 20:57   #13 (permalink)
gabiz_ro's Avatar
Member: 29006
Thanks Meter: 28
my ufs3 on many 5210 don't work but with same cabel work on 8210,8850,2100.read info ok (uses only mbus) flash not ok ,sometimes after more try flashing begin but aleator appear some errors,offcourse i used my old dct3 cable for 5210 and work ok,in one day open one 5210 and take a closer look and see:with ufs3 cable pins 2 and 4 make contact with plastic body of phone (wich is metalized inside) for pin 2 no problem is gnd but for pin 4 wich is tx that could be a problem. with my old cable distance between pins connector and plastic body of phone was enough to prevent such problem.later i found solution for this problem it was to obviously.on usf3 cable for 8850 there are 2 small screw used for placing good cable on phone if they are not proper calibrated cable will have some possibility of move and created bad contacts.so you can open one phone remove pcb insert cable and adjust the 2 screws until they are on the same level with body of phone that prevents cable to move or to be improper conected.
I hope you understand what I want to say.
Old 11-17-2004, 23:41   #14 (permalink)
zepi's Avatar
Member: 44417
Here is cable for 5210,tested
Old 12-08-2004, 21:11   #15 (permalink)
Member: 80073
Thanks Meter: 5
Use Knok 2k3 Version 5.30 Works Best.slower The Better.
i have problem with flashing e600 with ufs-3 petcy UFS2 + UFS3-Tornadoflasher 3 12-07-2004 19:58
Big Problem with flashing nokia 3650 with griffin Slavonac Griffin 11 06-12-2004 20:57
problem with nokia 5210 mix00 Nokia Hardware & Hardware Repair 2 05-28-2003 09:36
sound problems after flashing 5210 mobidoc Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 05-03-2002 06:13
Problem with flashing N3330 with full dejan box pali Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 02-20-2002 02:02
Page generated in 0.24445 seconds with 10 queries
