10-18-2011, 15:06 | #1 (permalink) |
Junior Member Join Date: Oct 2011
Member: 1674919 Status: Offline Thanks Meter: 1 | Problem while installing HWK/UFS Box on other PC I have purchased the HWK/UFS Box, successfully installed it on my Windows 7 PC and worked with it for some time. Then I had to connect the box to other Windows 7 PC. I have done the following. 1. Connected the box to the computer. 2. Installed the latest available HWK Support Suite (v. 02.2.000) and USB drivers. 3. Launched the HWK Updater. 4. Started the HWK update. Here is the log of the process: Code: ---------- HWK upgrade started:*.*.2011 17:01:54 ---------- -- Target Id : **** -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003. -- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007. -- UFSx S/N : **** -- Features : 00000001 -- Licence 5 : True -- UFSx Vendor: TORNADO -- HWK ID : **** -- HWK Status : 1, DL: 0 ---------- Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server connection successfully established. Authenticating on server... Authentication successfull. Checking upgrade client version... Your upgrade client is up-to-date. Upgrading HWK... HWK upgrade process completed. ---------- HWK upgrade finished:17:02:04 ---------- 5. Started the installation of HWK Major Suite (v. 02.2.000). The installation failed with the following error: "Your PC contained Alien registry keys which have been removed. Update your HWK on PC with the latest Update Client". The same error has appeared when I tried to install HWK Suite Minor (v. 02.20.001 or v. 02.20.002). I have attempted to update HWK one more time and re-launch the installation of the HWK Suite. Also I have tried to clean the registry, reinstall the Support Suite, re-activate HWK and then launch the HWK Suite installation again. I have even tried to wait for several days and repeat the whole procedure. But none of this had helped. When I attach the box to my first PC, reinstall the software packages and update HWK there everything is OK. Could you please help me to solve this problem? |
The Following User Says Thank You to HardwareUser For This Useful Post: |
10-18-2011, 15:40 | #2 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | This is bcoz of reg problem Quote:
10-19-2011, 12:34 | #4 (permalink) |
Member: 1674919 Status: Offline Thanks Meter: 1 | I have tried to delete the HKLM\Software\SarasSoft branch and also look for other registry entries containing HWK in their names. But this hasn't helped much. Could you please suggest where else in the registry should I look? |
10-20-2011, 16:53 | #5 (permalink) | |
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
The Following User Says Thank You to srinibas For This Useful Post: |
10-24-2011, 12:44 | #6 (permalink) |
Member: 1674919 Status: Offline Thanks Meter: 1 | I have installed Windows 7 on clean PC and tried to work with UFS box on it but met the same issue. Finally I have decided to install Windows XP on that PC and it solved the problem. I think this would be an acceptable solution for some time. |
07-03-2013, 20:42 | #7 (permalink) |
Insane Poster Join Date: Jul 2012 Location: apple mobile durbar main gate
Member: 1790945 Status: Offline Thanks Meter: 6 | i v formated my pc with xp,service pack 2,window 7...n also tried removing registry files but same result..."Your pc contains alien registry keys which has been removes. so update ur box with latest update client" . I was getting the above error message. plzzzz help some1... |
07-21-2013, 18:23 | #8 (permalink) |
Junior Member Join Date: Apr 2011 Location: Kurunegala,Nikaweratiya Age: 33
Member: 1557133 Status: Offline Sonork: nihab Thanks Meter: 1 | sir pls help me i installed ufs hwk but i cann't install the update client i see a error massege pls help me how solwe the problame Upgrade log: ---------- HWK Update Client v 2.2.0.0 ---------- ---------- HWK upgrade started:7/21/2013 10:39:34 PM ---------- -- Target Id : -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003. -- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007. -- UFSx S/N : -- Features : 00000001 -- Licence 5 : True -- UFSx Vendor: TORNADO -- HWK ID : -- HWK Status : 1, DL: 8 ---------- Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server connection successfully established. Authenticating on server... Authentication stage error: Error: Server returned unrecognized reply this is my fault pls help me |
The Following User Says Thank You to nihab For This Useful Post: |
07-21-2013, 19:15 | #13 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: Free Palestine
Member: 330579 Status: Offline Thanks Meter: 67,515 | Quote:
Regards | |
07-25-2013, 14:07 | #14 (permalink) |
Member: 1557163 Status: Offline Thanks Meter: 2 | Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server connection successfully established. Authenticating on server... Authentication stage error: Error: Server returned unrecognized reply |
07-28-2013, 14:36 | #15 (permalink) |
Major Poster Join Date: Apr 2013
Member: 1920990 Status: Offline Thanks Meter: 6 | sir pls help me i installed ufs hwk but i cann't install the update client i see a error massege pls help me how solwe the problame Upgrade log: ---------- HWK Update Client v 2.2.0.0 ---------- ---------- HWK upgrade started:7/21/2013 10:39:34 PM ---------- -- Target Id : -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003. -- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007. -- UFSx S/N : -- Features : 00000001 -- Licence 5 : True -- UFSx Vendor: TORNADO -- HWK ID : -- HWK Status : 1, DL: 8 ---------- Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server connection successfully established. Authenticating on server... Authentication stage error: Error: Server returned unrecognized reply |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
