01-13-2005, 08:09 | #5 (permalink) | |
Freak Poster Join Date: Apr 2003 Location: Vancouver, Canada Age: 56
Member: 26867 Status: Offline Thanks Meter: 3 | Quote:
any suggestions other than using another box./ | |
01-13-2005, 17:21 | #6 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | Maybe you can try "Reset MMI" with out battery. If the fone goes to API mode, it should be done. Then rebuild IMEI. Or vice-versa . It did it with c100 (just like the same way to kick off "Phone failure Contact Profider") Flash it 10000 times just waste your time. Its some kind Permanent locked. |
01-13-2005, 17:43 | #7 (permalink) |
No Life Poster Join Date: Jul 2003 Location: Amman Age: 41
Member: 35002 Status: Offline Sonork: 100.98829 Thanks Meter: 167 | you flash the phone full flash then unlock the phone tested and the proplem sloved 100% with ufs3 flasher but you need full flash only br |
01-13-2005, 18:05 | #8 (permalink) | |
Cheater -Don't Deal with him- Join Date: Mar 2004 Location: GERMANY Age: 42
Member: 60523 Status: Offline Thanks Meter: 9 | Quote:
try to flash it full flash like arabic flash 96 M and deal with it as D410 THEN UNLOCK IT IT WILL BE OK B.R ROBISH | |
01-13-2005, 18:07 | #9 (permalink) | |
Member: 35002 Status: Offline Sonork: 100.98829 Thanks Meter: 167 | Quote:
hi in new ver you can use e715 without any proplem br | |
01-13-2005, 19:59 | #10 (permalink) |
No Life Poster Join Date: Jun 2004 Location: MACEDONIA
Member: 67805 Status: Offline Thanks Meter: 364 | I have one dead E715 and I can`t flash him and on soft gives me this info: Region: 1, 0x00000000-0x00FFFFFF, Length: 16777216 bytes 1st Boot Ok, McuId: 000203BC, Rom: 00004545, 3-2.2 FlashLoader Failed: sync1 Any HELP? WBR |
03-02-2005, 13:42 | #12 (permalink) | |
NO NEED FOR REMOVW BACKUP BATTRY ONLY FLASH THE PHONE WITH FULL FLASH 96 M B.R ROBISH | |
Samsung d807 Phone Locked Return To Service error - How to fix? | Reema | VLSI, Conexant, Skyworks and Old Models | 2 | 12-23-2008 16:13 |
***NEW X450 winimei here***repair phone locked return to service on new agere phones | Elco | Trident/AGERE Platform | 22 | 09-01-2004 20:31 |
E710 - Phone locked return to servicing | Burnt Cobba | SYSOL Platform | 14 | 05-27-2004 12:39 |
is there solution for q100 Phone locked return to servicing | twrana | Trident/AGERE Platform | 31 | 08-05-2003 15:58 |
q100 Phone locked return to servicing??? | twrana | Trident/AGERE Platform | 0 | 03-11-2003 20:29 |
