03-16-2005, 02:11 | #1 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Denmark Age: 45
Member: 4205 Status: Offline Thanks Meter: 9 | Flashing 6230, now not responding? I flashed my 6230 to 5.26 yesterday, without any problems. Today I tried to flash it to 5.35, but in the middle of erasing, something went wrong (the %-bar became red, and the process stopped). Now I can't do anything. The phone can't turn on (which is easy to understand, since some of the flash is erased). What worse is, that I can't get it into local or test mode. My box can't connect/communicate with the phone. Any ideas? |
03-16-2005, 12:32 | #3 (permalink) |
Freak Poster Join Date: Mar 2004 Location: VoiD
Member: 59737 Status: Offline Sonork: 100.1603188 Thanks Meter: 18 | Your phone will not power on or get into local or test mode. You must manually select correct model (RH-12) and correct MCU + PPM and then click Flash button and phone will start flashing. |
03-16-2005, 14:07 | #4 (permalink) | |
No Life Poster Join Date: Apr 2000 Age: 55
Member: 1246 Status: Offline Thanks Meter: 25 | Quote:
choose the mcu, ppm etc uncheck the autodetect product flash and it shall work now | |
03-16-2005, 14:41 | #6 (permalink) | |
Laxxe where did u get the 5.35 from? did u check that bt is working? | |
03-19-2005, 09:25 | #10 (permalink) |
Junior Member Join Date: Mar 2005 Age: 64
Member: 127748 Status: Offline Thanks Meter: 0 | having bought 2 blue metal boxes none will run on any pc error error box error1020,ufs2xx.dll not found but its there,ufsx device not found,fpi32,dll not fondtwistersuite has caused an error and will close,access violation at address 00000000 syntax error,i have spent £250 and now read that the 13 disks contain crap the files dont work the software on them is out of sdate then go join a forum with 16,000 other winging people like me what is going on,come on write a software packed and make it plug and play like redbox easy access site fully upto date inm now serfing the net looking for downloads support and hey ive got better things to do am i the only one total unhappy with this package yes i know eventualy i will find were all the files are but it shouldnt be like that disk one should have the right exe the right dll etc. so can anyone direct me to were the correct files are without saying spend ya ******* bank holiday weekend searching pal. you dont go out buy a new car and get told an hour later by the way you need to update the tyres they are faulty by the way update the exhaust its faulty and it wont run untill you upgrade the engine. YES IM P****d. |
MR VYGIS flash eroor phone not respond TE365 /KS360 | kaspy | VygisToolbox | 25 | 04-02-2010 00:46 |
Flash 6230/6230i not working, HELP | mproltd | Universalbox | 2 | 11-14-2008 18:30 |
6280 flashing problem, phone not responding | pearsonjohnboy | MT-BOX | 5 | 06-23-2007 18:02 |
V300 help. bad flash.. now not responding | tical | Smart-Clip | 7 | 08-05-2006 21:18 |
try to flash 6230 now its dead | benie | UFS2 + UFS3-Tornadoflasher | 11 | 02-23-2005 11:59 |
