02-23-2005, 02:20 | #1 (permalink) |
Freak Poster Join Date: Oct 2002 Location: UK
Member: 16494 Status: Offline Thanks Meter: 6 | UFS 3 and 3410 flash file problem...? Tried d/loading the 3410 file again from support site but still does not install n e ideas plse ...... |
03-09-2005, 15:01 | #3 (permalink) |
Junior Member Join Date: Dec 2004 Location: Barcelona, Spain Age: 52
Member: 99876 Status: Offline Thanks Meter: 0 | Installed okay for me - on third attempt Managed to install this fine on the third attempt but strangely this involved copying it from on machine to another. Downloading directly to the machine it failed every time. transfering it using a flash drive has worked on all machines - weird! |
03-12-2005, 16:41 | #6 (permalink) |
Freak Poster Join Date: Mar 2005 Age: 48
Member: 122265 Status: Offline Thanks Meter: 10 | Hi, I think i've found the solution (I suppose you're using WIN XP?) I've the same problem and the reason was no autoexec.nt file (or empty file) in windows\sysyem32 I've found this file on another (working) computer and copied it into this folder. I don't know why this file wasn't created during installation... Here is source of this file: @echo off lh %SystemRoot%\system32\mscdexnt.exe lh %SystemRoot%\system32\redir lh %SystemRoot%\system32\dosx and i think the key are two last lines (second is something with cd drive, i've copied it all ;-)) So, create Autoexec.nt file in your windows\system32\ directory and you should can run Dctx_Ufs_13i_ins.exe and Dctx_Ufs_13h_ins.exe installation. Don't forget make an empty c:\wintesla directory to avoid troubles during install i hope it helps... |
03-12-2005, 17:23 | #7 (permalink) |
No Life Poster Join Date: Dec 2003 Location: SWEDEN
Member: 45814 Status: Offline Thanks Meter: 34 | This file is in the repairfolder of your computer, go and copy that file and put in windows system32 folder. And then it will work. I think that this is easyer to do ???? Br Bernie |
Ufs-3+orignal HWk flashing problem | mohsin10 | HWK | 13 | 11-25-2008 21:28 |
2865 tata flash file for use ufs-3 and ub | ~:Sujyot GSM Zone:~ | Nokia CDMA | 3 | 10-21-2008 10:03 |
nokia dct 4 and ufo flash files problem | darl izo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-07-2005 07:46 |
UFS-3 and 2100 flashing question, please... | fotisvoula | UFS2 + UFS3-Tornadoflasher | 4 | 03-31-2005 13:37 |
1100 RH-38 "Contact Serivce" after flashing with UFS-3 and IMEI ??????? | LionNar | Nokia Digital Core Technology 4 ( DCT-4 ) | 11 | 10-30-2004 20:02 |
